mm1040
ty50
im sorta stuck with a sealed box.... .75inch per side. a bit more than what this sub calls for. still ok? or should i change the box?
what ios a good way to make a .75inch chamber smaller?
yes I'm a noobster.
thanx
also, a pdx 1000.1 or the polk C500.1. wich one to use as I have both sitting on bench?
thanx
yes I'm a noobster.
thanx
thanx
Post edited by ty50 on
stuck? sealed is my usual preference also recommended and .75 sounds ok to me. only slightly higher than recommended. could reinforce inside with another panel or two or dynamat it. pdxPolk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
