DSW Pro 500
I just got this sub and it's really good. (Compared to my HTIB sub). The only problem I have is that it does not seem to auto detect the LFE channel when set to auto. I have it hooked up to an Onkyo 606 receiver. My old sub automatically came on but this one doesn't. Anyone have this sub with this problem?
Post edited by CyberChulo on
    Toolfan66 Posts: 18,223
    edited May 2009
    My guess is it's in your receiver setting. I have never messed around with an Onkyo receiver, But i had to change the settings in my Pioneer.
    I do have the 500 as well and it is set to auto.
    Maybe someone with an Oynko will chime in.
  • bevo
    bevo Posts: 306
    edited May 2009
    You may have to turn up your sub's level db setting on your receiver, so that it sends a stronger signal to your sub.
    That's one of the answers I have heard when people have this problem. Mine is at 15db and it works perfect, but from what I hear a setting as high as mine could cause the sub to distort depending on how good of a receiver you have.
    Denon 1909, want to upgrade for pre outs
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Panasonic plasma 50 inch
    Buttkicker(don't use or need it anymore since getting the Ultra)
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2009
    This is a common problem with these subs. I just leave mine set to on all the time & turn off the led.
  • danz1906
    danz1906 Posts: 5,144
    edited May 2009
    cfrizz wrote: »
    This the best way with that sub.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • CyberChulo
    CyberChulo Posts: 2
    edited May 2009
    Thanks for you help guys. I guess it's an issue with Onkyo Receiver and the Polk sub. I'll set it to standby mode and turn it on and off automatically with my Logitech universal remote.
