How Efficient Are Your 2 Channel Speakers?
megasat16
megasat16 Posts: 3,521
edited May 2009 in Speakers
Hi!
I am interested in finding out what's your favorite 2 channel speakers running in your stereo rig.
Do you use Tube Gears (Tube CDP, Tube Pre or Tube Amp or all or any combination) and do you hear a slight hiss from the speakers at a really close up.
Thanks for sharing your experiences!
James
Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
Post edited by megasat16 on
  • tcrossma
    tcrossma Posts: 1,301
    edited May 2009
    I don't have a lot of experience with different speakers, but I'm running LSi15's and am pretty happy with them. With my current gear it is dead silent even with my ear right up to the tweeter.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • nikolas812
    nikolas812 Posts: 2,915
    edited May 2009
    Right now Monitor 5B's with peerless tweets and upgraded crossovers. Efficiency is 91db. Ran with a Single Ended Tube amp with about 5-7wpc... Its dead quite.
    Nick
  • steveinaz
    steveinaz Posts: 19,538
    edited May 2009
    I'm running a SS 205 watt amp into 92dB/1watt speakers. With the volume maxed, I can hear a faint hiss when my ear is right at the tweeter.
    treitz3 Posts: 19,275
    edited May 2009
    It depends on the genre of music I am listening too, as well as what speakers I am running at the time. Everything affects everything as MM says. To answer your question? Anywhere between 1.6 ohms to 8 [not nominally].
  • dougy
    dougy Posts: 182
    edited May 2009
    My LSi-9's are rated 88db sensitivity...and I don't need no stinking tubes!
    Silence is golden!
    THE MAN-CAVE 5.1 CHANNEL A/V RIG
    Sony KDS-60A3000
    a/d/s/ HT-400LCR (3)
    a/d/s/ HT-300 (2)
    Velodyne DLS-4000R (2)
    Pioneer Elite VSX-55TXi
    Pioneer Elite DV-47Ai
    Sony BDP-S300
    Sony SLV-779HF
    DirecTV HD sat. receiver
    MAN-CAVE 2-CHANNEL RIG (shares sources with a/v system)
    Adcom GFA-5500
    Bose 901 Series VI
    NAD C-165BEE
    Slim Devices Squeezebox Classic
    TEAC CD-RW890
    Technics SL-BD20D w/ Audio-Technica P34
    Akai HX-A3X
  • lightman1
    lightman1 Posts: 10,794
    edited May 2009
    Nothing but brute force sent to the bookies. Nothing but dead silence between tracks, even if I could stick my head into the voice coils.
  • lightman1
    edited May 2009
    megasat16 wrote: »
    Hi!
    James
    Sorry, Mega. 5Jr, Moni 5 or Moni 7's.
  • george daniel
    george daniel Posts: 12,096
    edited May 2009
    1C's,, tubed pre and power.
  • lightman1
    edited May 2009
    Fook you George.;)
  • lightman1
    edited May 2009
    Why aren't you at Jerry's?
  • george daniel
    edited May 2009
    Unsure of the agenda-plan on going over Sat,,are you there?
  • lightman1
    edited May 2009
    Nope. Hadda work more than I wished today. bummer.
  • Face
    Face Posts: 14,340
    edited May 2009
    Rig 1. 94db, all SS, no hiss, line conditioner/UPS
    Rig 2. 85db, tube integrated, no hiss, line conditioner
    Rig 3. 91db, tube integrated, hiss, no line conditioning
    See the trend.
    mhardy6647 Posts: 34,054
    edited May 2009
    Altec Valencias in the living room. 16 ohm; ca. 100 dB per (watt? 2.83 VAC? who knows?).
    A better answer is probably the old Rolls-Royce response to questions about engine horsepower: "Adequate".
    heiney9 Posts: 25,221
    edited May 2009
    1C's SS power and pre very slight hiss with out power cond. 88dB; RDO's, Sonicaps, Mills
    dead quiet with power cond. no more slight ground loop hum either.
    5B's toob integrated no power cond. very slight hiss have to put my ear to the tweeter and has to be dead quiet in the room to hear. 89dB
    5B's have RDO's Solen, Mills
  • nikolas812
    edited May 2009
    Are the 5B's 89db? I thought they were 91db. Maybe thats the JR's I'm thinking of..
    Nick
  • Ern Dog
    Ern Dog Posts: 2,237
    edited May 2009
    I got tubes everywhere. My speakers are 94db, or somewhere around there, 4ohms. Using 90 WPC tube amp. And I have a fooken loud hum... tried everything under the sun to no avail. Dealer says will fix for $150.
  • BlueFox
    BlueFox Posts: 15,251
    edited May 2009
    PSB Synchrony One Towers. From their web-page:
    Anechoic Chamber 88 dB
    Typical Listening Room 90 dB
    Nominal 4 Ohms
    Minimum 4 Ohmns
    Powered by 2 Cambridge-Audio 840W in mono mode; 800w at 4 ohm
    Dead quiet. Loving every second.
    edited May 2009
    nikolas812 wrote: »
    Nick
    It depends on which Polk manual you read.......I guess. Mine are early 5B's with fuses the manual says 6 ohm and 90dB. Another owner's manual states 4 ohms and 91dB. So yes your close, but then so am I :)
  • nikolas812
    edited May 2009
    Hilarious.
    I also thought they were 8ohms. Wow. The more I learn about them the more I think they are wrong for my setup. I have a SET amp with 8ohm taps only and about 5wpc. I don't think there sensitivity or impedance are a good match..
    Can't wait to get my Frugal Horns here. SolidSqual and I are going to go get them on the 20th. I think they'll be better suited for my amp being a single driver speaker with an 8ohm load and a 95db sensitivity rating. I have high hopes for them anyway. We shall see....
    Nick
  • danz1906
    danz1906 Posts: 5,144
    edited May 2009
    LINN AV5140s
    90dB
    4ohms
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • zingo
    zingo Posts: 11,258
    edited May 2009
    SRS 4.1TLs at 91db with 16wpc tubes; plenty of power. Although, every once and a while I hook up the 450wpc Carver. :D
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2009
    I think you are mixing sensitivity with efficiency they are not the same thing.
    Tubes Rule...No hiss.
    RT1
  • 1fastz28
    1fastz28 Posts: 122
    edited May 2009
    leroyjr1 wrote: »
    thats awfully high for an efficiency rating
    setup
    Panasonic 46pz85
    Polk RTi A9's
    Polk CSi A6
    FXi A6's
    Energy s12.3 sub
    Denon 3808ci
    Pioneer elite dv-79
    Monster 1850
    Denon dp500m w/ grado green
    PS3,XBOX 360, NES
    edited May 2009
    well, not really... but some of the later Klipsch products' sensivity claims stretch credibility.
    I cannot really say for that particular speaker system if it's verity or balderdash.
    The "Heritage" series Klipsch Cornwall was 100 dB/2.83 VAC/1 m (that one I can vouch for, as a former owner).
    A Lowther twincone fullrange driver like the PM-6 is 104 dB/2.83 VAC/1 m
    2.83 V is 1 Watt into 8 ohms.
    Some of the (e.g.) JBL pro sound drivers have sensitivites of 107 dB/2.83 VAC/1 m
    They are very costly.
    You need that kind of sensitivity if you're filling a stadium or using, say, Bob Danielak's "DC Darling" amplifier (single ended 1626 for about 750 mW per channel) in your living room.
    http://www.geocities.com/bobdanielak/darling.html
    http://www.enjoythemusic.com/bostonbash99/
  • 1fastz28
    1fastz28 Posts: 122
    edited May 2009
    i sell home theatre, but nothing special in terms of high end brands, we carry
    polk, energy, klipsch, focal and i think the highest efficiency out of any of them is like 91 or so, thats why the 100+ was a shock
    setup
    Panasonic 46pz85
    Polk RTi A9's
    Polk CSi A6
    FXi A6's
    Energy s12.3 sub
    Denon 3808ci
    Pioneer elite dv-79
    Monster 1850
    PS3,XBOX 360, NES
  • megasat16
    edited May 2009
    RT1
    I don't think I am confused about the term Sensitivity and Efficiency. :)
    I mean it when I asked. :D
    My definition of hiss is where the sound comes from the tweeter or upper end of the mid-range where it's more like a bit of air letting lose from leakey gauge of the compressor valve. Usually, one can only hear a slight hiss if you listen up close the tweeter.
    I believe Hum / Buzz would be a bit louder sound and more prominent from the distance. It could comes from mid-range driver / woofers / sub-woofers.
    The efficiency of the speaker is largely important to hear or not hear the low signal such as a slight hiss or not but usually hum or buzz is more powerful signal so even the lower efficiency speaker may not completely mask the noise.
    Now, if you have a more efficient speaker (higher sensitivity), you may hear the lowest noise which may be a slight hiss originated from Pre-amp or amp part of the chain or even the source.
    My rigs when used with all SS gears are completely quiet and no hiss of any kind when listening up close with the volume on the preamp set at 1/3 of max.
    I've been playing with the Tube Pre in the chain and I could hear a slight hiss coming from LSi25. But when used with less efficient speaker such as Carver Amazing Platinum, the hiss is not noticeable.
    Note to RT1 : Tubes Are Bewitching! Beware the Power of The Tubey Curse!
    edited May 2009
    SPL is a measure of speaker sensitivity; typically measurd as SPL in dB per 2.83 volts AC input at a distance of 1 meter.
    Efficiency is just that, a measure of how efficiently a loudspeaker transduces electrical power into acoustic power. Efficiency is usually measured in percent.
    They are related but neither the same nor interchangeable.
    I, like many folks, do misuse the term "efficiency" on the hifi boards, but it is good for all to know the correct meaning of the term.
    http://www.sengpielaudio.com/calculator-efficiency.htm
    As a rule of thumb, a large orchestra playing at full tilt (say, fffff!) has an acoustic power output of 1 watt (and is maybe 100 dB at a reasonable listening distance!). If you need to put 100 electrical watts into a loudspeaker to get 1 acoustic watt out, the efficiency of that speaker is 1%.
    All amplifiers produce noise (hiss and hum). Hiss is thermal/shot noise from the active devices (tube or soiled state); hum is incompletely filtered AC from the power supply (and or induced from inadequate or improper grounding). The S/N of a good amplifier might be 100 dB, but with high-sensitivity speakers, if you put your ear up close, you'll hear it.
    Most of my tube amps produce audible hum on high-sensitivity speakers. The quietest tube amp in the house, paradoxically, is the cheapest: the little S-5 Electronics push-pull 11BM8 amp is dead-quiet on the Valencias.
  • ahardy17
    ahardy17 Posts: 84
    edited May 2009
    mhardy6647...i like your last name if that's it :D haha
    In-Car:
    Head Unit: Sony MEX-1GP
    Door speakers: Infinity Kappa 680.9cs
    Rear speakers: Polk db690
    Subwoofers: Memphis Audio 15-M3124
    Amps: Pioneer GM5300T, Kenwood KAC 6020, Memphis Audio MCD1.1100
    In-Home:
    Harmon/Kardon AVR 230
    Harmon/Kardon DVD 101
    Yamaha RX-V995
    Bose 161
    Bose 901
    Polk FXi30
