SVS Cylinder
Sorry if this has been done before, but are the cylinder offerings from SVS the same as their boxed brothers? A friend of mine just bought the PC-13 ultra cylinder and I've been really interested in hearing the ultra 13 for a while now. Just curious if the cylinder can be expected to perform the same as the boxed version, which I've heard so many good things about.
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
Post edited by mhartman29 on
  • danger boy
    danger boy Posts: 15,722
    edited May 2009
    Yes the SVS cylinder subs are just as good. keep in mind they are as big as a small water heater.. :p;):D but dig pretty low. :)
    PolkFest 2012, who's going>?
  • kuntasensei
    kuntasensei Posts: 3,263
    edited May 2009
    Yeah, they're big... but it's vertical space. The actual footprint on the floor is nice and small, so they don't take up much space. Mine fits nicely next to my left RTi70 tower.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Ron Temple
    Ron Temple Posts: 3,212
    edited May 2009
    The PC13 doesn't measure as well in groundplane testing, not quite as flat, but that's attributable to having the port 90 degrees and 4' above the driver where the microphone is inline. In room, the cylinder loses about a db in the deepest bass, but I dare anyone to hear a difference.
    You're going to be very impressed with the sub unless the setup or room is truly awful.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2009
    So in theory, the "box" and "Cylinder" offerings from SVS should sound roughly the same? (i.e. PB12-NSD = PC12-NSD)?
    Aside from cost, what advantage does the Cylinder have over the box version?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Ron Temple
    edited May 2009
    appadv wrote: »
    Well, they've changed the cylinder line, so it's not quite a tuning match anymore for the PC12NSD. It's in the 31" tube that I think is tuned to 20hz (with curvy ports), but the PB12NSD is tuned to 18hz (larger volume). So you're going to get a bit more bottom from that box. The Plus line is in the 39" tube which is a stock 20hz tune and the Ultra in a 46"er (used to be a 16hz natural tune, but I doubt it's tuned that low now)...not sure what the Plus box is or the Ultra for that matter, but since they all have variable tuning it's a moot point.
    The only real differences are looks, footprint and weight. The boxes have a higher material cost plus finish upgrades, thus the price differences. However, in talking to SVS, I'm told the tubes are a bigger pain to build and take longer. I've owned a cylinder. I wasn't thrilled with it's looks so I hid it, but it was a stellar performer...and being able to pick it up was a real plus ;). My Ultra13 looks wonderful, but it's too long for easy placement and really discouraging to move around. I usually wait until I have help.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
