Toe-in
organ
Just something that's been bothering me for a long time.
EVERY speaker I've had in my rig sound their best when toed in so the drivers would face my ears. I noticed that no toe in or very little of it gives me a larger sense of space. But I lose definition, focus and image. It just never sounds right with no toe-in.
Now, when I see pics of some really high end stuff (people's personal set ups, CES, HES, etc), why is it that MOST of them have their speakers facing straight forward??? Are some speakers designed to sound better off axies? I find this weird because drivers should have their flattest response on-axies, right? Do a lot of people like that 'spacey' effect of off axis?
I'm still quite puzzled
Post edited by organ on
Nice setup Z.
My LSi15's sound best *to me* when facing straight forward. Toe-ing them in doesn't really hurt them much, but it doesn't improve things and to me it collapses the soundstage a little bit.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
I've noticed a wider soundstage (less toe in) vs a deeper soundstage (more toe in).
I think it really depends on the room. I had a set of speakers that sounded good toed in and then with my new set sound better not toed. The best thing to do is to move them around and find out what sounds best to you. That all that matters is when you listen to them and it sounds good to you. To toe or not to toe, 1' away from wall or 18" to 4" away. Everyone is different and every room is different. It took me about 2 weeks of moving my speakers around to find were I think they sound good.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
omg Sean, beautiful set up man! What speakers do you connect to that big MC?
Thanks for the helpful post. Seriously man, I don't think they ever have any audio shows over here. In the next few years, maybe I'll go to Vegas to check out the HES. Been wanting to do it for a couple yeas now.
TC,
Where are your tweeters pointing? I think the LSi should require less toe-in because of the location of the tweeters.
Madmax,
Yeah, I noticed the same thing too. I think some poeple refer to it as the "horse shoe effect". But you're saying you didn't loose focus and definition with less toe-in?
Thuff,
I noticed that. But it's just that I've gone through countless speakers and every single one of them had to be toed in. That's why I posted this. I'm beginning to think the room may also determine the amount of toe-in you need. -
Zero what do those little monitors run$$? Any sonic comparisons?Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
There are also some speakers that are designed to be placed straight forward, but incorporate their own "toe-in" with a slanted baffle. NHT 3.3s come to mind.
I find that toe-in really does depend on the speaker and the room. The best results with toe-in that I have found is almost all nearfield monitors; it makes all the difference in the world. -
As a more more extreme example, Jordan JX92s drivers are supposed to be toed in 60 degrees- you can even toe them out as an alternative.
http://www.ejjordan.co.uk/diy/
(look at the triangular design)
Anyhow, it'll depend on room and how wide you want your listening area to be. Try a few different things- that's the fun part.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Very nice setup, Sean!! nothing like seeing and breathing anything Mac....I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
This has been my experience also.I've noticed a wider soundstage (less toe in) vs a deeper soundstage (more toe in).
madmax
IMO, the most important thing is the speakers used. If it's a well designed speaker with great off axis response, you should be able to run very little to zero toe and enjoy a huge soundstage."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Sean,
Thanks for the info. I'm sure they sound super. Have you tried spreading them out a little more? I believe you had your LSi15's farther apart before. Is that Karan a pre? Man, I need to keep up. I thought that was your int. and had the mac for another set of speaks.
I forgot about the Montreal show. I should check it out. I'm so wanting to hear an MBL system.
Thanks to everyone for clarifying the set up for me. I did some reading last night and found that there are people who prefer the sound of speakers off axis. They sacrifice imaging and focus to get a much wider soundstage. The full blown orchestra listeners like the wider stage and greater sense of air.
I have played around with the RT1000's and I think I found a very good angle. The sound intersects just behind my head now. -
Just to check this out, I set my speakers straight forward and found a significant increase in the soundstage, but also lost something in the deal too.
With both my 7A's and my RTi8's, I prefer a bit of toe-in. Not to the point of firing directly at my ears, but to where they fire past the side of my head and intersect basically right behind my head.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
So many factors, one of the LARGEST of which is your listening room, affect the overall sound of your system. Great speakers can be made to sound like crap in a bad room with improper location/setup. Toe-in/out is just one tiny aspect of the total system compilation.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Impossible! Your melon is too big Curt.
That does complicate things. I have to have them spread at least 25 feet apart just to be able to hear any separation between the channels. This is with me sitting 9 feet away from the center point!:eek:The nirvana inducer-
Ive tried toe out, toe in, straight forward and everything in between. I always come back to the same degree of toe in. Pretty much have the speakers firing slightly away from their corresponding ear... and this works wonderful...
But straight forward yields excellent staging with a lackluster center image and a loss of overall detail. Which is what I try to accomplish. But the width of the stage is still incredibly wide.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »Ive tried toe out, toe in, straight forward and everything in between. I always come back to the same degree of toe in. Pretty much have the speakers firing slightly away from their corresponding ear... and this works wonderful...
Yep. Me, too.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
There are two possible ways around that, move the speakers a little closer together and/or run the tweeters a little hot. Again, the speaker's off axis performance is also a factor.Vr3MxStyler2k3 wrote: »But straight forward yields excellent staging with a lackluster center image and a loss of overall detail. Which is what I try to accomplish. But the width of the stage is still incredibly wide."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Sean,
Forgot about pic distortion. I never tried them closer than the equilateral triangle distance I get. I should try it out next time I'm in the mood to play around with placement.
Must be nice to have two killer integrates to play around with.
