Kicker Car Audio Products
rdb2001
Because of the recent burglary of my truck, I am selling my car audio and going back to factory audio. I hate to do this but replacing what they took and taking the chance it might happen again overwhelms me.
I have for sale the heart of my system. Kicker ZX700.5 5 channel amp I ran infinity kappa perfect components of this amp along with the sub and box I am selling
5-Channel Amplifier with Class D 5th Channel for Subwoofer(s)
RMS Power Rating:
4 ohms: 70 watts x 4 chan. + 210 watts x 1 Class D Sub channel
2 ohms: 85 watts x 4 chan. + 420 watts x 1 Class D Sub channel
4 ohms (bridged): 130 watts x 2 chan. + 420 watts x 1 chan. (2 ohms sub channel, 210 watts @ 4 ohms)
Bass Boost Remote Control: 0 - 18dB at 40Hz
CEA-2006 Compliant
24dB per octave Crossover:
Active at 50Hz - 200Hz
High Pass, Low Pass, or Full-Pass selectable
4 gauge power/ground leads
Dimensions: 20"L x 9 5/8"W x 2 1/8"H
Kicker 07CVR154 15 inch dual 4 ohm subwoofer in custom Audio Enhancers box built for this sub.
sub specs
15" CompVR Series Subwoofer
Power Handling:
Peak: 1000 watts
RMS: 500 watts
Inverted Structural Dome Polymineral Injection Molded Cone: Remains rigid, and lowers distortion
Ribbed Santoprene Surround for Linear Cone Motion
Rear Cone Brace: Offers unmatched strength and resistance to deformation
Silver-Coated Stamped Steel Basket
Stitched Surround: Ensures the cone and surround won't separate, even under the highest loads
High-temp Polyimide Film Voice Coil Former
Dual Ultra-Length Voice Coils
Perimeter Venting
Sleeved High-Power Tinsel Lead Wires
Spring Loaded Nickel-Plated Terminals
115oz. Magnet structure
Box specs
KPVR15S
Enclosure Volume: 5.63 Cu. Ft
Dimensions: W 35 H 17 TD 20 1/4 BD 20 1/4
Nitro 1.5 farad capacitor
1.5 Farad 24 VDC Surge High Performance Capacitor
Capacitance: 1,200,000uF
Max Voltage: 24 VDC
Max Temp: 90 °C
Digital Voltage Monitor
Asking $230 plus shipping for amp. It will also include 2 rockford fosfate 17ft rca cables and remote bass knob for sub channel ( add 3% for paypal) retails for 600 new
Sub and box combo. Local Pick up only as this sub and box weighs over 80 lbs asking 225
Capacitor 30 plus shipping ( add 3% for paypal)
Here is a pic of the job they did on my truck
RMS Power Rating:
CEA-2006 Compliant
sub specs
Power Handling:
Peak: 1000 watts
RMS: 500 watts
Perimeter Venting
Box specs
KPVR15S
Max Voltage: 24 VDC
Max Temp: 90 °C
Post edited by rdb2001 on
Ouch. I'll let you know if I find anyone that needs anything over here.Tschüss
Zach -
Sub and box Pics
okiepolkie wrote: »Ouch. I'll let you know if I find anyone that needs anything over here.
Thanks I appreciate it. -
Fri Night Bump
So sorry to hear of your troubles.
1. Windows tinted on truck? What they don't see they don't know.
2. Don't play it loud in your neighborhood.
3. Watch for people will follow you to find where you live.
Those things should help to deter them.
Good luck on your sellengtaz
only got off w/ HU? what kind? sure coulda been a LOT worse.(amp, box, truck etc.) count your blessings. good advice from engtaz. could also include an alarm(one that works). if it helps i got my $600 HU stolen past winter along w/ smashed window and passenger door lock destroyed. still no lock, but HU is back! also left amps, components and sub..Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
cadenceclipse wrote: »only got off w/ HU? what kind? sure coulda been a LOT worse.(amp, box, truck etc.) count your blessings. good advice from engtaz. could also include an alarm(one that works). if it helps i got my $600 HU stolen past winter along w/ smashed window and passenger door lock destroyed. still no lock, but HU is back! also left amps, components and sub..
Yeah they got off with my jvc avx800 double din touchscreen HU which when I bought it retailed for about 750. They broke my tinted front window. My amp was hidden and that box was too big and heavy for a quick steal. I probably will eventually replace it with the big brother the avx810 with the only double din that has a detachable face if I cant sell the rest of my gear. -
Evening Bump
Afternoon bump
PM on the capIf life had more tubes it would be a lot smoother.
weekend bump. I am negotiable on the prices guys:D
I probably will eventually replace it with the big brother the avx810 with the only double din that has a detachable face if I cant sell the rest of my gear.:p
pret auto -
Bumpity
Capacitor is sold.
