Good musical sub?
KrazyMofo24
I am currently looking for a good sub that will go well with my Vienna Acoustics Haydn's. I have heard good things about Rel's B2's and B3's but at $2,000 they are out of my budget. I prefer it to sound great for music, more so than HT.
Any suggestions would be appreciated.
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
Post edited by KrazyMofo24 on
I am sure there are some good Polk subs but I don't have a lot of experance with them. I do know that Sunfire are good and I have had a few Definitive Technology subs.
What is your budget?Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
Look at the new Polk Micro Pro series of Subs, they are excellent for music, nice tight, musical bass."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul!
Check out the smaller REL's T1, T2. They are much cheaper and have very good reviews linking with 2 channel systems.
Venom -
Running dual Velo SPL-1200R subs for music & HT...I'm one happy camper to say the least. Definetely check out the Velo line."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
Velodyne subs in that mid-range are among the best for music and HT...not overly powerful or pushing too hard to do what they do. I, second ...001s suggestions above.
If you want to spend a couple thousand or so...yeah there are better. But you'll be happy with a Velo.
Velo or REL, those two are good with music.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Thanks for the recommendations. I know of one dealer that had the Rel subs and will give them a listen to a few when I get closer to being able to buy one. Zero I will keep a look out for that Storm if you decide to sell it.Setup:
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI -
Not that I am an expert at all, but VMPS gets my vote. They do it correctly...huge boxes with huge woofers. Check out the some of the VMPS subs and at least take them into consideration.
I don't know exactly what your budget is but for less than $320 delivered and an hour of time putting together I have heard some really good things about this sub, and they have other more powerful subs too.
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=300-770&scqty=1 -
I'd check out the Rytmik line carried by Ascend Acoustics and the HSU ULS-15.
I have a couple rytmiks subs in DIY 2cu/ft sealed enclosures and they are excellent for music. -
Another satisfied Velo user here. My velo is super clean, flat and sounds excellent.
I haven't heard anyone mention SVS. I'm getting ready to order the pb-13 ultra. Is there something I don't know about it, some reason I should stay away from it?Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra) -
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Venom
I 2nd that,,,,,,,,Go for the REL subs:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Venom
This would be my suggestion as well. The T2's I've installed are phenomenal for the price.Tschüss
Zach -
I love the way my Snell sounds. Very musical IMO.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
pearsall001 wrote: »Running dual Velo SPL-1200R subs for music & HT...I'm one happy camper to say the least. Definetely check out the Velo line.
+1 even if you have only one. Looks great in piano black, and very compact. Absolutely no regrets, except that I may now have too much base with my Lsi25s :eek:MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s -
I'm no Velodyne fan either.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I've used plenty of Velodyne subwoofers for installations, and they tend to be my go-to sub in some applications. Their SC series works very well in custom installations. As of late, I've been spec'ing the REL T series for entry level systems, and I usually spec 2(or more) of them in larger rooms. The T series blends very well with the Haydn's, and is actually a recommended setup by Vienna Acoustics.Tschüss
Zach -
There's that ACI subwoofer on Audiogon that looks delicious. I think it goes down to 18Hz or something? Now THAT's bass you feel but don't hear.SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
To date, the best subwoofer I have ever heard (and I've heard a few, SVS PC Ultra, Wilson Audio Watch Dog, M&K) would be the VMPS Larger Subwoofer with Megawoofers.
115db, 20hz -- sealed, push pull, slot loaded passive radiator - every positive attribute you can imagine, its got it. And its cheap. What more can you want? Its VERY accurate.
However, I think in about 2 weeks - the accuracy part of that may change when my new subs get here.. but the VMPS will always be my HT sub. The volume per dollar CANNOT be beat.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I don't have any personal experience with them because they're out of my price range but I have heard a lot of good things about some of the MartinLogan subs.
Hi. I would take a look at these. Very muscial subs and all are highly regarded. In no particular order:
-Onix Rocket UFW-10 (great performer and inexpensive)
-Vandersteen 2W (hard to find but worth the look)
-JL Audio Fathom F110 (can find these for around $1300.00-$1400.00 used and will blow your house down) -
When ever I hear talk of a musical sub I can't help but think of...
Sorry, I couldn't resist:)Stan
Main 2ch:
HT:
Other stuff:
HSU has an excellent rep for having musical subs for a good price.
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
I'll second the HSU suggestion. I got one a few months back and I love it!
Here is the answer for your search, KrazyMofo24:
http://cgi.ebay.com/VELODYNE-DD-15-Digital-Drive-Series-Subwoofer_W0QQitemZ350182518017QQcmdZViewItem
Enjoy the Sub!
Lots of great recommendations. My budget is around $500-600, and looking at mid to late June to make my decision. I'm looking at used or new I'm leaning towards Rel, or Totem right now. However I am going to do some more research.
Basically looking to upgrade my system and specifically 2 channel, I just picked up a B&K ST-202, Parasound preamp so I think the sub is my next big upgrade since the sub I have now is only good for HT.
Thanks again for all your guys input, I have a lot of good options now.Setup:
I decided to pick up a Velodyne VX-10 on sale for $130 at Fry's. I decided that I want to get a great sub like the JL Fathom F112 or Rel B-Series something that will be a final upgrade. Again thanks for the recommendations I will look in to these further when the time comes to make that big purchase.Setup:
Congrats on the Velo sub!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
