VM20 or RTIA5?
arriagadaa
Hi, before to pull the trigger I need to know wich speakers (front) are better: VM20 or RTIA5.
Could you help me please?
thanks
thanks
Post edited by arriagadaa on
I think the RTiA line of speakers sounds great. The VM series goes well with a flat screen TV, but the sound is not thier strongest point. (in my opinion - I have demoed them, but not listened in home. Based on what I heard, I would purchase the RTiA and never even consider the VM's....
I don't think I've ever seen anyone here talk about the VM series, at least as an owner. There are always questions about them (and RM-xx) but they generally go unanswered. I don't know for sure if that's because they aren't good, but I know I'd get the RTi A5 and never look back.Currently listening to:
Marantz SR5004
Sony BDP-S370
Apple TV V2
Audio Technica AT-LP120
Mirage CMD-5 x 5
Bic H-100 -
With something like the VM's, you're going to give away performance in lieu of a small enclosure. I own the RTi A5's and have been impressed since day one. My vote would definitely be the A5's
Fronts: Energy RC-70
Center: Energy RC-LCR
Surrounds: Energy Veritas 1.0CM
Subwoofer: SVS PC12-NSD
Receiver: Onkyo TX-SR705
Amplifier: Denon POA-2200 w/ Ben's ICs
Pics of my setup (click me) -
Go for the RTiA5.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
wow, thank you all for your fast replies and help.
I will buy the RTIA5.
I have the RM85 and I bought the FXIA4 for the surround. Now I want to change the central speaker for a VM20 because I'm getting a very good price ($170).
Do you suggest me to buy the VM20 (central)? (the CSI4 is double of price)
thanks -
You will remember you got a center that does not match your fronts much longer than you will remember the savings....
Wait for a good sale and run a phantom center as long as needed until you can swing the one that matches... (RTiA4, RTiA6, CSi3 or CSi5)Mains.............Polk LSi15 (Cherry)
thanks again. Sorry but my noobie question, but is it important to buy all front speakers (front+center) of the same line? It will be a lot of difference between central VM20 and CSI4?
thanks -
arriagadaa wrote: »thanks again. Sorry but my noobie question, but is it important to buy all front speakers (front+center) of the same line? It will be a lot of difference between central VM20 and CSI4?
thanks
Yes - you want your front 3 speakers to match. (be from the same line)
Depending on your seating and speaker arrangements - you may like running without a center channel so it may at least be worth while to try just the RTiA5's first before you spend the money on a center. (personally - I usually like a center channel in a home theater, but others whose opinion I respect, have had good luck without one.)
There is benefit from all speakers in your theater matching, but the rear speakers are the least important for this. (i.e. - upgrade your rears last if money is an issue)
wow thanks McLoki.
I will pass the VM20. You saved me money . Now I need to wait good deals for RTIA5 and CSI4. The big problem is I'm from Canada and it's akmost impossible to get good deals here. If I buy from USA I will pay insane rates for shipping and also high custom charges.
thanks
