Emerald Physics
pearsall001
Anybody ever get your ears on a pair of these? Intriging design to say the least. If you did hear them...thoughts & opinions on how they sounded.
Post edited by pearsall001 on
I've owned a pair for over a year now. The open-dipole bass is amazing. I most likely will never go back to box speakers. You'd be hard pressed to find a better speaker at many times the price. I just traded my CS2s in to move up the Emmy line. I will be a customer for a long time. The continued customer support is excellent.
SlowcarIX also has a pair. Haven't heard from him in a while though. -
I knew somebody here had a pair but I wasn't sure. From what I've read they mate superbly with ICE power. And I see you have a pair of W4S monos. I take it that synergy is a foot with that pairing. Awesome sound I can imagine. I've got to get out & give a listen."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
I've listened to the CS2's. Could have been the room, gear or set up, but they didn't float my boat. I also understand that the required stock Behringer crossover leaves a lot to be desired and they don't like tube amps, at all.Political Correctness'.........defined
President of Club Polk -
Yeah, that is probally the one thing I do not like about Emerald -- anything with Behringer associated with it... eh...
I sell alot of Behringer gear and there is a reason they have a 1 year replacement warranty....
I replace probally 20 pieces every 2 months. The speakers overall look pretty solid.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The speakers sound very good when setup properly with the right gear. I've had no issues with the Behringer DCX2496 and have heard of no other Emmy owners having issues. That being said, they are switching to the DBX PX for more processing horsepower and in-room correction.
I am sorry, behringer is the bose of pro audio, well not exactly as behringer stuff sells very cheap, I have heard though many good things about these Emerald speakers.
RT1 -
Pearsall: Check out my review.
www.affordableaudio.org/EmeraldPhysicsCS2.pdf
I had them in for a review for 3 months, when setup properly, they throw out a soundstage that is incredible. My only wish is that I could have heard them with a pair of quality solid state amps rather than class d, which to my ears sound a bit dry and lean. But still, they are stunning.
As for Behringer, I know that some of their products have a significant failure rate, but the DCX2496 that comes with the EP's has not been a problem. Probably because Clayton Shaw powers up each one in order to program it, therefore weeding out any faulty units.
They've just released the 2nd generation of three models, the WAF is much, much higher.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
For those who have heard them, would you recommend a sub or would you think one would be necessary to complete the spectrum of frequencies? I'm not talking about a PSW10 either.....~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I have tried REL subs, ML subs, SVS subs, and others. Despite trying to tune them to the room, none of them can produce the same open and articulate bass of the CS2 based on my experience. The sound was just not the same. At any rate, the CS2 provides more than enough bass for music once you get them dialed in.
My impulse to get a sub was mainly for HT. But, when I would use one for music and then go back to the two speakers alone, I would be reminded of how amazing bass from the CS2 is. It's fast, it's articulate and most importantly it's not a one-note thud. -
pearsall001 wrote: »Anybody ever get your ears on a pair of these? Intriging design to say the least. If you did hear them...thoughts & opinions on how they sounded.
i got a paif of cs2 - they throw a soundstage so lucid, on good recordings, its so eerie to have person/instruments distinctly in the listening area. for 2ch listening, they care capable of handling pretty much anything.
for ht, i let the subs handle the subsonics to 50Hz and the cs2 takes over from there. very dynamic, capable of making one jump in quite a few soundtracks.
must be the dipole design and the direct speaker/amp drive that makes them work so well...idk i will be keeping them for a long timemy 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
SolidSqual wrote: »I've owned a pair for over a year now. The open-dipole bass is amazing. I most likely will never go back to box speakers. You'd be hard pressed to find a better speaker at many times the price. I just traded my CS2s in to move up the Emmy line. I will be a customer for a long time. The continued customer support is excellent.
u got the cs1? :eek:
+1 for cs support from walter and clayton!my 7.(1x4) HT setup
Buttkicker
Nope CS2.3 is on order. The CS2.3 is said to sound better than the CS1 according to Clayton Shaw. The CS3 and CS2.3 have a new technology that will be used to redesign the CS1.
i'll change to the 2.3 too. the mid/high drive for the 2.3 mains will be coaxial like the one on my jtr 12lf.my 7.(1x4) HT setup
Buttkicker
It's hard to beat the imaging of a good coax, true point source."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
have u heard the thiel 3.7 with the interesting mid/hi driver?
my 7.(1x4) HT setup
Buttkicker
No I haven't, but would love to."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Check out Hawthorne, too.
http://www.hawthorneaudio.com/drivers.htm#SI
I've heard the eminence coaxial units, but this one has the Qt tweaked for OB use.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
very interesting - are the hawthorn drivers tweeked eminence units?
http://www.hawthorneaudio.com/speakers.htm - the duet is very resonably priced, ditch the xover for a dcx2496 and active tri-amp...will be interesting !my 7.(1x4) HT setup
Buttkicker
Yep. And it's my suspicion that the new Emerald 2.3's are based around Eminence coaxial units, too, given the use of the eminence drivers in the CS-2's.
The Eminence Beta CX models have a lower Qts, so they're questionable for an OB alignment, so Hawthorne talked them into producing one that would work better.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
