23 inch widescreen
[Deleted User]
I purchased the Dell S2309W 1080p widescreen. The viewing angle sucks. You must be seated at the perfect level, sit properly at that level and not deviate any degrees left, right, up or down else, you will feel like you are on acid or tripping or whatever. Deviate and you will see wierd things, maybe I am not use to distortion. Damn it, I missed the 23 inch samsung deal. But again, I can not complain for the price.
Halen
Halen
Geez I would return it lol.halenhoang wrote: »I purchased the Dell S2309W 1080p widescreen. The viewing angle sucks. You must be seated at the perfect level, sit properly at that level and not deviate any degrees left, right, up or down else, you will feel like you are on acid or tripping or whatever. Deviate and you will see wierd things, maybe I am not use to distortion. Damn it, I missed the 23 inch samsung deal. But again, I can not complain for the price.
Halen
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
What do you recommend Snow?
Halen -
return it and buy Samsung 226BWShoot the jumper.....................BALLIN.............!!!!!
My only reccomendations are first return the damn thing if it doesnt work for you and secondly listen to Sherardp or anyone who has more experience with these type of products than I do. If at all possible look at as many as you can at your local stores then if you see something that you can live with order one.halenhoang wrote: »What do you recommend Snow?
Halen
Sounds like a TN panel - most bottom tier LCDs have this panel type which has a ver small proper viewing angle. This really becomes an issue with larger panels - my friend's 20" is hell on the eyes.God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
What's your budget?
