Experience with OPPO DV-980-H
Bernal
Bernal Posts: 991
edited May 2009 in Speakers
HI,
I would like to hear experiences.
YOUR VIEWS ON THE OPPO DV-980.
REFERENCES HAVE GIVEN ME GOOD TEAM.
THANKS FOR YOUR HELP.:)
Post edited by Bernal on
  • Bernal
    Bernal Posts: 991
    edited May 2009
    Universal DVD Player Features:
    DVD-Audio, Super Audio CD (SACD) and DVD-Video universal playback
    Compatible with Audio CD, HDCD, WMA, Kodak Picture CD, and other digital audio/video/picture media and formats* (*Note: The DV-981HD does not play Blu-Ray nor HD-DVD discs)
    Official DivX® Certified product, certified to the Home Theater Profile
    Plays all versions of DivX® video (including DivX® 6) with standard playback of DivX® media files
    Plays XviD and .SRT, .SMI, .IDX and .SUB format
    Compatible with CD-R/RW, DVD±R/RW and DVD+R DL* (*Note: Compatibility with user-encoded contents or user-created discs is on a best effort basis with no guarantee due to the variation of media, software and techniques used. For example, Discs recorded on some stand-alone DVD recorders or DVD camcorders may not exhibit smooth playback. )
    Video Up-Conversion Features:
    High definition up-conversion with film-like picture quality to up-convert 720x480 interlaced video encoded on DVD discs to 480p/720p/1080i and 1080p
    DCDi by Faroudja video processing technology with progressive scan, film mode detection, TrueLife™ enhancement and motion adaptive noise reduction.
    Video is analyzed on a single pixel granularity to detect presence or absence of angled lines and edges, which are then processed to produce a smooth natural looking image without visible artifacts (jaggies)
    High-quality pure digital video and audio through a single HDMI (High Definition Multimedia Interface) cable
    Multiple high definition video formats through HDMI output: NTSC: 480p/720p/1080i/1080p; PAL: 576p/720p/1080i/1080p
    Compatible with HDTV, HD-Ready TV, HDTV monitors and projectors with an HDMI or DVI input
    Direct PAL/NTSC disc and TV compatibility and system conversion
    For more information about DVD video up-conversion, please read our white paper article Getting the Most out of DVD on an HDTV Display
    Supports screen aspect ratio 4:3 (standard) and 16:9 (wide-screen)
    User adjustable video controls: Sharpness, Contrast, Brightness, and Saturation
    Composite video and S-Video outputs (standard-definition output only)
    Optimized Audio Features:
    High-resolution multi-channel digital audio output through HDMI supporting CD, DVD-Audio, SACD, Dolby Digital and DTS sound tracks.
    Individual analog 5.1-channel surround and down-mixed stereo outputs
    24-bit, 192kHz high resolution audio D/A converters
    Optical and coaxial digital audio outputs with DTS, Dolby Digital, Dolby Pro-Logic II and Linear PCM support
    3D Surround (Virtual Surround): Concert, Live, Dance, Techno, Classic, Soft
    Built-in equalizer, channel trim and channel delay functions
    Compatibility Features:
    PAL/NTSC disc and TV compatible with automatic or manual system conversion
    Dual-laser optical pickup head with excellent error correction
    Enhanced dual-layer disc support with fast layer change
    Wide range universal power supply (~100V-240V, 50/60Hz AC)
    Convenience Features:
    Special disc tray - thin, flexible and strong. Can tolerate some bending without breaking.
    Smooth and easy navigation of photo albums, music collections and video files on DVD and CD
    Selectable subtitle and audio tracks
    Discrete ON/OFF remote control IR code for programmable universal remote controls
    Connectors:
    HDMI - High Definition Multimedia Interface: 1
    Analog Stereo Audio (Mixed 2-Channel Left/Right): 1 group (2 connectors)
    Analog 5.1 Channel Audio: 1 group (6 connectors)
    S/PDIF (IEC-958) Coaxial Digital Audio: 1
    S/PDIF (IEC-958) Optical Digital Audio: 1
    Composite Video: 1
    S-Video: 1
    No Component Video (YPbPr/YCbCr) on the DV-981HD model. This model is designed for use with a display device with HDMI or DVI digital video input.
    Accessories Included:
    High-quality certified HDMI cable with gold-plated HDMI connectors
    Remote control with "glow in the dark" keypad (batteries included)
    Stereo audio cable
    Composite video cable
    User manual and warranty information
    Specifications:
    Designs and specifications are subject to change without notice.
    Disc Types:
    DVD-Video, DVD-Audio, Super Audio CD (SACD), DivX®, XviD, Audio CD, HDCD, Kodak Picture CD* (*Note: The DV-981HD does not play Blu-Ray nor HD-DVD discs)
    Plays all versions of DivX® video (including DivX® 6) with standard playback of DivX® media files with encoded video resolution up to 720x480 30fps and 720x576 25fps
    CD-R/RW, DVD+R/RW, DVD-R/RW, DVD+R DL* (*Note: Compatibility with user-encoded contents or user-created discs is on a best effort basis with no guarantee due to the variation of media, software and techniques used. For example, Discs recorded on some stand-alone DVD recorders or DVD camcorders may not exhibit smooth playback. )
    Output:
    Analog Audio: Stereo, 5.1ch
    Digital Audio: Coaxial, Optical, HDMI
    Analog Video: Composite, S-Video (Y/C) - standard-definition output only
    Digital Video: HDMI with HDCP (NTSC 480p/720p/1080i/1080p, PAL 576p/720p/1080i/1080p)
    No Component Video Output. The DV-981HD is designed for use with a display device with HDMI or DVI digital video input.
    Video Characteristics:
    HDMI: HDMI Specifications 1.1, CEA-861-B
    S-Video Amplitude: Y: 1.0Vp-p (75 Ohm), C: 0.286Vp-p (75 Ohm)
    Composite Video Amplitude: 1.0Vp-p (75 Ohm)
    Audio Characteristics (Nominal specification):
    Frequency: 20Hz – 20kHz (+/-1dB)
    Signal-to-Noise Ratio: >100dB
    Total Harmonic Distortion: < 0.01%
    General Specification:
    Power Supply: ~ 100V – 240V, 50/60Hz AC
    Power Consumption: 20W
    Dimensions: 420mm x 270mm x 41mm, 16-1/2 x 10-5/8 x 1-5/8 inches
    Mass: 2.4kg / 5.20 lbs (DVD player unit only)
    Operating Temperature:
    5°C - 35°C
    41°F - 95°F
    Operating Humidity:
    15% - 75% No condensation
    Firmware Updates:
    Upgradeable via CD-ROM/USB
    *DivX, DivX Certified, and associated logos are trademarks of DivX, Inc. and are used under license.
  • Bernal
    Bernal Posts: 991
    edited May 2009
    Compatible with Audio CD, HDCD, WMA, Kodak Picture CD, and other digital audio/video/picture media and formats* (*Note: The DV-980H does not play Blu-Ray nor HD-DVD discs)
    High resolution picture slide show
    Compatible with CD-R/RW, DVD±R/RW and DVD+R DL* (*Note: Compatibility with user-encoded contents or user-created discs is on a best effort basis with no guarantee due to the variation of media, software and techniques used. For example, Discs recorded on some stand-alone DVD recorders or DVD camcorders may not exhibit smooth playback.)
    High definition up-conversion with increased picture clarity. Up-converts standard definition video on DVD discs to 480p/720p/1080i and 1080p Full HD resolutions.
    Motion-adaptive, edge-adaptive and inverse telecine progressive scan technology to produce a smooth and natural looking image.
    Multiple high definition output formats – NTSC: 1080p/1080i/720p/480p/480i, PAL: 1080p/1080i/720p/576p/576i
    Compatible with HDTV, HD-Ready TV, HDTV monitors and projectors with an HDMI or DVI input (HDCP support is required)
    PAL and NTSC compatible with system conversion
    User adjustable video controls: Sharpness, Contrast, Brightness, Saturation and Gamma
    Component video output with progressive scan (Up-converting over component output is only available for unencrypted DVD discs such as home video and consumer-created contents. Most commercially pressed DVD discs are CSS-encrypted and will be limited to 480i/480p output over component. HDMI output is protected with HDCP and has no such restriction.)
    USB 2.0 interface for video, picture and music playback
    10-disc memory resume
    Direct Stream Digital (DSD) over HDMI (Requires compatible A/V receiver)
    Individual analog 7.1-channel surround outputs, compatible with 5.1-channel and down-mixed stereo.
    Dolby Digital Surround EX decoding
    Built-in equalizer, channel trim, channel delay and lip-sync (audio delay) functions
    Connectors:
    Component Video (YPbPr/YCbCr): 1 group (3 RCA connectors)
    Analog 7.1-Channel Audio: 1 group (8 RCA connectors, may be configured as 5.1-channel or stereo)
    S/PDIF (IEC-958) Coaxial Digital Audio: 1 (RCA connector)
    S/PDIF (IEC-958) Optical Digital Audio: 1 (TOSLINK connector)
    Composite Video: 1 (RCA connector)
    S-Video: 1 (S-Video connector)
  • VXR8
    VXR8 Posts: 291
    edited May 2009
    Hi Bernal,
    I have the said player and find it to be a great bang for buck player. If you are looking for a player that does everything, you cannot by-pass this player.
    For me personally now, I have added a dedicated CD player and find both the PS3 and my Toshiba HD-DVD player upscale video better (PS3 and HD-DVD player connected via HDMI also). I now primarily utilise the Oppo player for SACD playback only, through HDMI, for which I find very satisfactory - hope this helps.
    Regards - Gaz from the land of Oz
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    Cambridge Audio - Azur 851C - CXUHD
    Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
    SVS - PB1000 x 2
    Foxtel - iQ4
    Belkin - Pure AV PF40
    Sony K77A9G
    Front Room System
    PS Audio - Sprout 100
    Cambridge Audio - CXC S2 - CA752BD
    Sony - UBX800 4K BluRay
    Polk Audio - Legend L200
  • nikolas812
    nikolas812 Posts: 2,915
    edited May 2009
    I found the upconversion to be great.
    The SACD playback was good.
    The redbook playback was poor.
    JMO
    YMMV
    Nick
