RM8 with RM75 package...
Chuck_IV
Chuck_IV Posts: 2
edited May 2009 in Speakers
I picked up the RM75 5 speaker package yesterday and am thrilled with it. However, I want to add 2 more speakers for my 7.1 setup.
My decision is whether to just add 2 more RM7 speakers for a complete 5 speaker match or add the 2 RM8 package and use them as from L/R speakers and move the 2 RM7 to the back as RR/RL speakers.
My only concern is how well the RM8 speakers will go with the RM7 center, which came with the RM75 package. Will the RM8's mesh well with RM7 center or should I just stick with more 2 RM7s?
FYI I have a Mirage S8 as my sub for this setup, if that makes a difference.
Thanx for reading.
Post edited by Chuck_IV on
  • bevo
    bevo Posts: 306
    edited May 2009
    I use the rm 8's for sides and rears. If I were I would look into upgrading my fronts and center to something in the RTi line. You can find the rti a bookshelves on polk direct for almost the same price as the rm8's, then you could get an CSi A4 center and have a really nice sounding system for the money.
    I think the rm8's sound pretty goo with my fronts, I wish they had more bottom end, but I will take care of that in the future. Right now I'm getting ready to order an svs pb13 ultra sub, and that will be it for a long while.
    Denon 1909, want to upgrade for pre outs
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Panasonic plasma 50 inch
    Buttkicker(don't use or need it anymore since getting the Ultra)
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2009
    Chuck_IV wrote: »
    Thanx for reading.
    The RM8 will be perfect and that's a good idea.
  • Chuck_IV
    Chuck_IV Posts: 2
    edited May 2009
    Thanx for the input.
    I ended up finding a really good deal on the RM85 package(price was about the same as what I paid for the RM75's, plus it included a fre set of Polk Outdoor speakers too), so I decided to just go with the RM85 package and will be returning the RM75 package. I also added 2 addition RM7 speakers for a 7.1 setup.
  • dorokusai
    edited May 2009
    That's awesome!
