Odyssey Candela / Stratos Extremes
Serendipity
Serendipity Posts: 6,975
edited May 2009 in 2 Channel Audio
So - I've been hearing a lot about this amp/preamp combo and I've got a few questions for you owners on the forum:
How does one integrate the amp and pre into a 2-channel system with receiver-like flexibility? There are a few things I commonly use in my 2ch setup that require an AVR, such as video switching and HDMI, when I play a concert DVD or use my HTPC.
I figure that I would need this:
http://www.anchorbaytech.com/products/systems/vp30.php
Also, a DAC like this to connect optical out from the HTPC:
http://www.cambridge-audio.us/summary.php?PID=320
Then, a speaker selector box for the patio speakers:
http://www.crutchfield.com/p_190SS4/Niles-SS-4.html?tp=2997
What I'm basically saying is that on a pre like the Candela, a lot of features are "given up" and thus requires additional components like scalers, DAC, and speaker selector to do what the Onkyo TX-SR806 can do out of the box.
Is there a better way to integrate a preamp into a system with Zone 2 speakers, Media Center, and a projector (how else do you watch a concert DVD?) And how to play DVD-A/SACD? I feel like I'm missing out on a lot with a receiver but at the same time can't figure how to get a system like this integrated...
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
    VR3 Posts: 29,762
    edited May 2009
    HT Bypass.
  • Serendipity
    edited May 2009
    Correct me if I'm wrong, but isn't HT bypass used to integrate your 2ch pre and surround processor together? Meaning connect the main outputs of the HT processor to the 2ch pre and then to the amp(s)?
    I'm looking for something like a "2ch bypass" instead. My system is already 2ch.
  • Serendipity
    edited May 2009
    Also, doesn't this bring along / amplify the characteristics of the receiver? What I don't want is to have the receiver in the signal path if it's going to be the weak link. HT Bypass doesn't solve that... as far as I understand.
  • danz1906
    danz1906 Posts: 5,144
    edited May 2009
    appadv wrote: »
    Your 2ch pre-amp would be for your Front speakers only.
    In the HT bypass, your amp would go thru your Pre-amp to
    your AVR.
    The Characteristics of the pre-amp would be ampify.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Serendipity
    edited May 2009
    danz1906 wrote: »
    your AVR.
    Thanks.
    What I don't like is that the characteristics of the AVR will still be amplified when in HT Bypass mode. Might as well connect the AVR directly to the amps then.
    My main issue is with sound quality on Concert DVD's and HD Cable.
    Also, I only have two speakers.
  • Early B.
    Early B. Posts: 7,900
    edited May 2009
    If you're gonna go get a Candela/Stratos combo, then why bother trying to integrate it with a bunch of sound quality-robbing HT crap, speaker selectors, DACs, etc.? That defeats the purpose. Just set up a separate 2-channel system or forget about it.
    "God grooves with tubes."
  • Serendipity
    edited May 2009
    Early B. wrote: »
    How would I listen to DVD-A then? Or watch the Music HD channel on Cable? A separate 2-channel system isn't going to let me utilize all of my sources.
  • Early B.
    edited May 2009
    appadv wrote: »
    How do you do it now?
  • Serendipity
    edited May 2009
    Through the receiver. It feeds the projector and powers the speakers.
    Cable box is connected via coax, and the HTPC is connected with an optical cable.
  • Serendipity
    edited May 2009
    I would need a DAC because the cable box's analog output is awful.
  • Face
    Face Posts: 14,340
    edited May 2009
    Keep your receiver for HT/Video, get a preamp with HT bypass, get a separate DAC, and get a separate power amp for your mains.
  • Serendipity
    edited May 2009
    Face wrote: »
    That works out very well.
    Thanks for solving my dilemma!!
