SDA II & Parasound HCA-1000A
jimbo1421
jimbo1421 Posts: 772
edited May 2009 in Vintage Speakers
There is an eBay sale ending shortly, SDA II, that I can pick up locally. I have a Parasound HCA-1000A to drive them, but nothing in my downloaded manual says anything about it being common ground. Does anyone know the answer?
Also, I am going to have trouble with the 3 foot side wall clearance, given furniture, door & window placement issues. Should I try for these or stick with my monitor 10s?
Jim
PS: these are the SDA2s with 2 midwoofers. Here's the link:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=330326771494&indexURL=0&photoDisplayType=2#ebayphotohosting
Please don't outbid me.
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
Post edited by jimbo1421 on
    F1nut Posts: 51,786
    edited May 2009
    Those are SDA 2A's with the blade/blade IC. I would worry about the other stuff later.
  • CLPolk
    CLPolk Posts: 133
    edited May 2009
    What the last guy said!! That cheap and close<>Go for it!!
    • SDA SRS 2
    • SDA 1A
    • Monitor 11
    • Monitor 7B
    • CS350lsi
    • RM-6600
    • FX500i
    edited May 2009
    If you can pick those up locally and the bid doesn't get much above 199 Finut and CLPolk are quite right. Make the last bid and get the car fired up!
    cnh
  • jimbo1421
    edited May 2009
    What about the common ground amp? Does the Parasound HCA-1000A have it?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • I-SIG
    I-SIG Posts: 2,243
    edited May 2009
    the amp is good.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
    nooshinjohn Posts: 25,928
    edited May 2009
    who cares about a common ground amp now...buy the speakers man! I do believe you will be ok with the Parasound...
  • jimbo1421
    edited May 2009
    Darn it! I cut it too close and bid seconds too late. I need to polish my sniping skills.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • Matt34
    Matt34 Posts: 318
    edited May 2009
    jimbo1421 wrote: »
    Jim
    I got them for $199 plus $36 shipping. I really wasn't expecting to win them.:eek:
  • jimbo1421
    edited May 2009
    Good for you, Matt. I hope they work well for you. Let us know how you like them.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • Matt34
    Matt34 Posts: 318
    edited May 2009
    jimbo1421 wrote: »
    Jim
    I will, my uncle had a pair years ago so they have some nostalgia behind them.
  • seeclear
    seeclear Posts: 1,244
    edited May 2009
    Read the listing, you may find that shipping is twice that. It shows $37 to me and I am fairly close (Colorado), but the listing says to double that. Hope that is still OK with you.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
    F1nut Posts: 51,786
    edited May 2009
    Yep,
    Seller's payment instructions
    Shipping calculator is for one speaker double calculator amount for total Enter Country and in shipping calculator to see cost. Include CONTACT NAME and PHONE NUMBER for all shipping. Will combine shipping where possible, so wait for invoice on multiple items.
  • Matt34
    Matt34 Posts: 318
    edited May 2009
    seeclear wrote: »
    I saw that and trying to get clarification on it now from the seller. When I hit pay now it comes up as $236.
    I'm in Arizona so if it's only another $36 I'm fine with that.
  • CLPolk
    CLPolk Posts: 133
    edited May 2009
    Check your mail box!! Better LUCK next time.
    • SDA SRS 2
    • SDA 1A
    • Monitor 11
    • Monitor 7B
    • CS350lsi
    • RM-6600
    • FX500i
