Small spade or ring terminals
fbm211
fbm211 Posts: 1,488
edited May 2009 in Wanted (WTB) Classifieds
I need 8 of these that would fit under a screw for a PS cap bypass mod for my adcom 565 amps.I intend to crimp or solder the caps to them for an easy and safe hook up.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    HD or lowe's has them. If they are crimp remove the insulation, crimp them, and then solder. Take one of the screws from the caps with you to size up the whole.
    Don't lose it;)
    Ben
