Using the SMS-1 to Control the LSi25s
praedet
praedet Posts: 314
edited May 2009 in Speakers
All right, I tried really hard to search for the answer to this, but for some reason it kept giving me no results searching for SMS-1 even though I found threads about them...
I am still trying to decide between the LSi15s and 25s for my mains in a 7.1 set-up. Disregarding that question, I am trying to figure out something about the 25s.
I am currently running an Outlaw 970 to a Outlaw 7700 w/ LSi9s and LSiFXs. My Subs (LFM-1 EX and PSW125) are run using a Velodyne SMS-1. I am planning on upgrading to the Outlaw 997 when it comes out, so this may all be mute w/ the Trinitov Processing, but I thought it was an interesting question.
In all my reading about the LSi25s, those that got them set-up properly liked them a lot, in a few cases, more than the LSi15s they had. Everyone else complains of the powered tower and an inability to get them set-up right.
To help w/ setting them up, What does everyone think about using the SMS-1 to control the powered subs in the 25s? That would allow me to integrate them well w/ the other subs, and the rest of the system. Thoughts?
Would this solve the adjustment and set-up problems?
Thanks,
Ted
HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
2 APC H-15s and a Panamax 5400 for good measure ;)
Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers
Post edited by praedet on
  • jinjuku
    jinjuku Posts: 1,523
    edited May 2009
    praedet wrote: »
    Thanks,
    Ted
    The SMS-1 is only meant to EQ one sub. You can chain multiple SMS-1's together.
  • praedet
    praedet Posts: 314
    edited May 2009
    ^^^^Incorrect, while it does not apply individual compensation, a single SMS-1 can tailor the sound of as many subs as you have. The modifications will simply be global modifications.
  • jinjuku
    edited May 2009
    praedet wrote: »
    The SMS-1 can only EQ 1 'sub'. Be that a physical single sub, or an array. Velodyne allows you to chain units together because some people will want to apply individual correction to each distinct sub.
    I am speaking about individual compensation, you are talking about correcting the room with both subs going at the same time and letting the SMS-1 make a best, overall guess.
    Either approach is valid. Just depends how far down the rabbit hole you want to spend.
    To the OP: You can use the SMS-1 to EQ both your subs. It will figure out a room average and apply it. If you want more control and feel like spending the $$ you can set up a house curve for each sub independently.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2009
    I would absolutely try it and see what you think, I personally like the powered subs Polk has put out and owned most of them as well.
    For HT I would think your Outlaw gear works well with the Lsi line-up, have you checked out the new Polk subs, I have listened to several and they are quite nice.
    RT1
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2009
    LSi15s and one SVS PB13U would hold you over for a very long time and you wouldnt even need to consider the 25s.
  • megasat16
    megasat16 Posts: 3,521
    edited May 2009
    jinjuku wrote: »
    Jinjuku,
    Praedet is the OP himself!
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • thsmith
    thsmith Posts: 6,082
    edited May 2009
    If you do not have a SMS-1 yet I suggest looking at Room Eq Wizard (REW free at hometheatershack.com) and a BFD1124F has 2 channels and would allow you to manage filters for 2 subs independently.
    All for less than $100 assuming you have a radio shack SPL meter, RCA cables and a PC sound card that supports MIC in.
    Granted it is not as easy as SMS but I figured it out using 3 subs so anyone can do it.
  • megasat16
    edited May 2009
    I have SMS-1 to control over all the subs in my HT room. I also have a pair of LSi25 but I used one PSW1000 for each tower. Instead of the SMS-1, I think using one dedicated sub with each channel (left and right) yields a lot better result and deeper bass. Subs in the LSi25 alone good but not getting a lot better with SMS-1. However, it gets a lot better if you use stereo subs with the LSi25.
    Just the results of my findings....
  • praedet
    praedet Posts: 314
    edited May 2009
    I am not going to be getting rid of the Subs I do have, I was more speaking towards using the SMS-1 I already have to possibly take over the bass properties of the LSi25...
