DTS Master audio & SDA SRS 2.3 in HT
bsoko2
bsoko2 Posts: 1,449
edited May 2009 in Vintage Speakers
Does anyone report any issues with BluRay audio in the DTS Master format. The issue that I have is that the audio can be abrasive unless it is turned down and then the bass goes to H***. I find that there is no problem with standard DVD audio in any format. Must be the diff between compressed and non compressed audio formats. Anybody have any suggestions for solving the issue such as upgrading the crossovers or drivers. Really love my 2.3's and hate to think that I would have to get another set of speakers just for BluRay audio.
Bill
Post edited by bsoko2 on
    F1nut Posts: 50,746
    edited April 2009
    If you still have the SL2000 tweeters, I would recommend upgrading to the RD0194-1 tweeters.
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    DTS sound tracks run real low. If the mains are set to full they can suffer from subsonic bass. I don't care what speakers you run DTS can wreak havoc. I literally tore the cone off of an 800wrms 15" Dayton Titanic Mark III sub with the gain set a we bit high on War of the Worlds chapter 13;)
    Ben
  • thsmith
    thsmith Posts: 6,082
    edited May 2009
    Which movie Bsoko?
    I have not witnessed any problems with PS3, my 1Cs are set to large and LFE is set to sub+mains
  • bsoko2
    bsoko2 Posts: 1,449
    edited May 2009
    thsmith wrote: »
    Which movie Bsoko?
    Try them small and see what I am talking about.
    I have updated the tweets with RD0194-1. "Maimi Vice" is one movie (freeway scene at the beginning to save friend with helo tracking) that is tough on the mains and they are set to small. I get too much bass in the room with bass "plus", too boomy. Just that some tracks with DTS are murder on the mains. One solution that I have found that helps is to engage THX Cinema 2. And like I said, no issues with plain standard DVD.
    Bill
  • Ron Temple
    Ron Temple Posts: 3,212
    edited May 2009
    I had some issues with uncompressed Dolby True HD, but not nasty highs, just muddy and bassy dialog. It's since fixed through a firmware patch. I'm kind of with Tracy on this one. Run the SDAs large and back the subs off unless you've got the 10db issue with the LFE channel. I run my sub flat (72db vs 75db) in sealed mode and at 70dbs vs 75dbs in 15hz mode. The SDAs handle deep and midbass with plenty of slam and the sub just accents the room without ever going into stress at major volumes...never a hint at being out of balance. Try letting your mains handle most of the front frequency response and see if that helps. Your 2.3s should be more than capable.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • bsoko2
    bsoko2 Posts: 1,449
    edited May 2009
    I believe that I have solved most of my problem. The first thing that was wrong was that I calibrated my setup with the interconnect cable in place. I have the "Dreadnaught" and it does as more dimension than a ordinary cable. Secondly, I had it connected all the time. I reran MCACC and have left the cable off for movie & TV watching. When watching movies, I unplug the cable from the transformer. Thanks for a nice interconnect unit Ben, it does the job better than expected.
    Bill
  • ben62670
    edited May 2009
    Ah now I know why you wanted to know where to disconnect it;) Thanks for the info. It will come in handy.
    Ben
    Ben
  • bsoko2
    bsoko2 Posts: 1,449
    edited May 2009
    ben62670 wrote: »
    Ben
    Yeh, it made a BIG difference in the audio.
    Bill
