Ok i am ready but need help. SDA SRS 1.2
Toolfan66
Toolfan66 Posts: 17,366
edited April 2009 in Speakers
For those of you that have upgraded you SDA's.
Should i just buy the RDO194's and be done with it?
Or should i just go with the RDO198's and upgrade the xovers? or stick with the RDO194's and upgrade the xovers? and if i go with upgrading the xovers can anyone please help me with what i would need to order to do this?
What would i really gain by doing the upgrade to the xovers?
I do know that i will change out the tweeters. Would just like some input or ideas on what direction would be best.
As soon as i am done with this part of my project i will look into what i want to power them.
Thanks,
Larry.
Post edited by Toolfan66 on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2009
    I'd go with the RDO-198 with a upgraded XO. I plan on doing this to my 2.3tl in the future. For now I'm enjoying them in there original form.
    Have you been able to listen to them yet?
    F1nut Posts: 50,838
    edited April 2009
    The RD0198-1 tweeter is the better sounding of the two, but to use them in your speakers would require reworking the high frequency circuit. If you can read a schematic and solder, it shouldn't be a big deal. If you can't, perhaps you could find someone like Ben to do it for you.
    A much better sounding set of speakers.
  • zarrdoss
    zarrdoss Posts: 2,562
    edited April 2009
    O come on, you wont be happy till you go all the way with these, lol
    edited April 2009
    leroyjr1 wrote: »
    Yes i have, I love them. With my SDA 2's i changed out the tweeter's with the RDO194's had no choice as the last owner had put a boston Acoustics tweeter in one speaker, WTH he was thinking i will never know. just about done refurbing those. Don't think i will redo the xovers though.
    edited April 2009
    I can read a schematic,and i can solder, and weld as well. I just need to know what to buy and where.
  • zarrdoss
    edited April 2009
    here is a link to sonic caps, just to get an idea
    http://soniccraft.com/sonicaps.htm
  • zarrdoss
    edited April 2009
    cant you do the 198 tweets with minimal x-over upgrade and then do a complete x-over latter? anyone?
  • ben62670
    ben62670 Posts: 15,969
    edited April 2009
    Thanks F1. I do a fair amount of rework on XO for Polkies on the cheap. Anyone is welcome to hit me up via email on upgrades. I am not out to make a living off of Polkies, but love to share what I know.
    thanks
    Ben
    Ben
  • leroyjr1
    edited April 2009
    Did you use your XPA-3 ?
    edited April 2009
    leroyjr1 wrote: »
    Yes i did once, it sounded good, but the Adcom 555II i borrowed from a friend
    was much better IMO.
  • ben62670
    edited April 2009
    OK TFL please expound on your thoughts. I do love Adcom's for the price, and I have heard EMO's in the same system. I will not say anything, but please tell me what you have heard.
    Thanks much.
    Ben
    Ben
    F1nut Posts: 50,838
    edited April 2009
    Ok, do you mean what brand or what values?
    The schematics for the 1.2 and the 1.2TL are posted here, just compare one with the other and you'll see what needs to be changed and the values needed. Choices in caps are vast, everything from the uber expensive Duelund's to the dirt cheap Solen's. Lots of folks are happy using Sonicap's. For the resisitors, Mills makes nice ones.
    edited April 2009
    ben62670 wrote: »
    Thanks much.
    Ben
    I found that the clarity with the 555II on the highs was much better, i like my XPA-3 i think it does a fine job. i just found that the clarity in the vocals was better with the adcom. these are the only 2 amps i have got to demo in my own home. I did get to hear a couple of rotels at listen up, and i really loved them. with that said i wish i could hear them with the SDA's in my home.
    edited April 2009
    Thanks, i have the schematics for the 1.2's but not the tl's i will look for them.
    F1nut Posts: 50,838
    edited April 2009
  • Face
    Face Posts: 14,340
    edited April 2009
    The swap doesn't appear difficult. If you don't feel that you're up to it, Ben or someone else here could help you out. As for which components to install, use the best your budget will allow.
    Do them up right.
  • leroyjr1
    edited April 2009
    I think it's time to sell me your A9's to fund your tweeter and crossover project.:D
