Phase linear lamps
DennisD
DennisD Posts: 1
edited April 2009 in DIY, Mods & Tweaks
Hi, I am a first time poster. I have a Phase Linear 400 amp that I use in my studio. Beauty is in the eye of the beholder because this amp is working great for last 15 years. My problem is that the lamps for the vu meters are burnt out. I pulled the meter pc board and there are no specs on the board. I used a magnifying glass to see if there were any codes on the lamps and there were none. I ran a multimeter across the circuit and got a reading of 5.3volts ac. But because the lamps are all burnt out I can't get a load reading to calculate the watts. I just downloaded the schematics from Musicparts.com and although they are fairly complete, any information in regards to the lamps and vu meters in missing. Is there anyone out there who may know what the voltage and wattage is I need for replacement lamps, or substitue lamps. I hate to keep downloading schematics to no avail. Thanks Dennis
Post edited by DennisD on
    edited April 2009
    I can't answer the question except to say that I've seen this amp in my local pawn shop...looked it up. It's a Carver design, but seems to have been mostly used for studio and live performances...where it supposedly often flamed out, literally catching fire. Don't those amps date to the mid-late 70s? The local one, I've considered picking up at some point and having someone tweak it also has the problem you described.
    Maybe someone knows a bit more about this. What speakers are you running off that.
    And WELCOME to CLUB POLK!!
    cnh
  • Systems
    Systems Posts: 14,872
    edited April 2009
    Hi Dennis,you might find a Phase Linear tech or 2 over at the Carver forum.http://www.carveraudio.com/phpBB3/index.php
    Testing
    Testing
    Testing
  • joeparaski
    joeparaski Posts: 1,865
    edited April 2009
    This is the item # on ebay: 120351899282
    A mere $6.50 buy it now.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
