Question for MXStyle
Paul Connor
Mx,
You mentioned in an earlier thread that you download music from Kazaa. After reading the thread I went looking around and downloaded a couple of songs. I then attempted to copy the files to cd and was unsuccessful. Kept getting a message that read something like "you cannot copy this file for whatever effin' reason" This may seem like a dumbass question, but is it possible to copy to cd?
Paul (aka novice music pirate)
Post edited by Paul Connor on
what r u using to copy with?
u will need a program, if u have XP - use Windows Media Player. All i can say is...unless it is an out of this world file...it should be able to go on a disk that is playable.
Another reason it might not of copied is u might of had something already on the cd...that could of been the problemDamn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
Mx,
Used a clean disk. I have Windows ME, but did not try to burn it through Media Player. I will give it a shot. I guess from your answer, it should not be a problem once I figure out where to make the tranfer. -
Copying to a cd is pretty easy, what program are u using? (or tried to use) if your cd player plays MP3's...u can just copy it from 'my computer'Damn you all, damn you all to hell.......
I promised myself
I will give it another try now and let you know.
ohh yeah, sorry for the long wait of reply...i dont come by the music section too often...lol - i sorda stake out at the off topic..lolDamn you all, damn you all to hell.......
I promised myself
TIME FOR BED! LOL! gl, ill check back in tommorow see how it went...maybe some of these old timers on here can help ya! LOL!Damn you all, damn you all to hell.......
I promised myself
Thanks, from one of the old timers. I'll keep trying.
lol...u get it to work? i gotta go at 12Damn you all, damn you all to hell.......
I promised myself
so how it go, u get it to work?Damn you all, damn you all to hell.......
I promised myself
Finally got out of bed huh?
Yes, and thanks for your help. I overlooked an important detail about basic cd 101. Guess I shouldn't try to use brain after 16 hours at work.
Paul -
lol...yep i finally moved outta bed! LOL! cool deal, enjoy burning your music....lol...Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
