Very Basic Question From a Bose-man
aljoseph
aljoseph Posts: 39
edited April 2009 in Electronics
I've had nothing but Bose for years so please excuse the naive question. Can most of the modern receivers also be used for sound processing and feeding (as in a true pre-amp) multi-channel amplifiers? So unless I'm laden with money, it's not necessary to buy the highest wattage receiver around if, at some point, I will use it with a separate amp. The reason, then, to upgrade the receiver is because newer models handle more/newer audio/video formats? If so, then shouldn't one invest in a quality amplifier as it is not as susceptible to becoming outdated as the receiver? Please steer me straight if you will. Thanks.
Pioneer SC-07
DVD - Pioneer BDP-51FD
Mains - Polk Audio RTA-8T's
Center - Polk Audio CSi 30
Surrounds - Polk Audio FXi 3's
Sub - Polk Audio PSW 450
Post edited by aljoseph on
  • tcrossma
    tcrossma Posts: 1,301
    edited April 2009
    Best I call tell you are perfectly correct in your logic on receivers (processors) and amplifiers. Get a good amp and keep it forever, and change receivers / processors as new technology becomes available.
    And welcome to CP.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
    edited April 2009
    +1 on that. A lot of us use a relatively 'recent' AVR as a pre-amp/processor and a power amp, often bought 'used' for the juice.
    cnh
  • aljoseph
    aljoseph Posts: 39
    edited April 2009
    Thank you sir. I kinda thought so, but it helps to turn to those in the know. Maybe in time I'll be able to help someone with a question.
    Pioneer SC-07
  • jinjuku
    jinjuku Posts: 1,523
    edited April 2009
    aljoseph wrote: »
    Some receivers can go pre-out. You can by pass their built in amplifiers so it is basically a pre-pro.
    Some receivers can go pre-in. Some do both.
    Now lets say you have a Blu-ray player capable of bit-streaming to LCPM audio. That is the BR player decodes the DTS and Dolby HD audio streams at the player. This means that your receiver doesn't need the HD audio formats integrated in it. The BR player simply passes on the un-encoded audio as LCPM over the HDMI cable. Your receiver does need to be able to support LCPM. This lessens the importance of a receiver with all the latest bells and whistles. I am looking to go receiver-less.
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited April 2009
    I like to see an honest Bose question here and it is refreshing to see some honest responses too! Bose makes some very good speakers. The topology with how Bose work is different from Polk speakers. Therefore, how everything ties together work differently
    Welcome to CP Aljoseph! Hang around and we can get you educated with why the Polk approach is better for sound reproduction than Bose. Just beware of some Polk fanboy/Bose bashing talk that can happen. Take in info and judge for yourself.
    Happy learning!
  • aljoseph
    aljoseph Posts: 39
    edited April 2009
    Thanks all. I can handle the Polk/fanboy, Bose/bash talk. I like honesty and integrity above all. If we can do that and have some fun while at it, so much the better. I wonder why it took me so long to "see the light".
    Pioneer SC-07
    nooshinjohn Posts: 25,928
    edited April 2009
    aljoseph wrote: »
    welcome to CP! there is just two words of advice I can give... BOSE BLOWS!:p
    J/K... and welcome.
    tonyb Posts: 33,072
    edited April 2009
    Welcome Joseph,and a well put post to boot.Nice to see some new members asking good questions for a change.Yes,a good amp can spand the technology upgrades that seem to come along on a yearly basis now.Trick is,getting one that meshes well with the other gear,and speakers you have.Some amps have a sonic signiture that is attached to the brand,while some are pretty nuetral in their sound and just amplify the signal given without any added flavor.Depends on what you like,so do some research,ask alot of questions,before plunking down your hard earned cash.Welcome again,enjoy the forum.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2009
    Shout out to Peoria, nice place. I would like to extend you a personal invitation to visit our unpcoming PolkFest........bring your Bose speaks, we'll bring the M-80's.........when you get their look for a guy called Antn'y and give the Bose to him.
    Enjoy your rig.
    RT1
  • aljoseph
    aljoseph Posts: 39
    edited April 2009
    I think I've found a home. It'll take me a while to become De-Bose'd (a new word I just coined) as I don't as yet have a complete system to take its place. Hopefully you'll put up with me till then. ;-)))
    Pioneer SC-07
  • cheddar
    cheddar Posts: 2,390
    edited April 2009
    jinjuku wrote: »
    Welcome to CP to the OP!
    The above post may be misleading. So just to be clear:
    You don't bitstream LPCM. You bitstream Dolby and DTS encoded (compressed files to make them smaller) audio files to a receiver for decoding (uncompression to PCM) there. Some blu-ray players will have the option of decoding in the blu-ray player and sending the PCM over HDMI to the receiver bypassing whatever decoding capabilities the receiver has. So, for instance, if the player decodes the lossless formats Dolby TrueHD and DTS-HD MA, then your receiver doesn't need to have these capabilities. But your receiver MUST support the processing of LPCM (almost all do) via HDMI in order to get the decoded PCM from the player. Once the receiver has the PCM by whichever method, it can apply all its digital processing (surround modes etc.) and get it converted to an analog signal for use by your speakers.
  • jinjuku
    edited April 2009
    cheddar wrote: »
    Sorry about that I should have made a clear delineation between Bit-Streaming and LPCM.
    LPCM is full un-compressed, already decoded audio, sent to a receivers multi-channel inputs via HDMI (most of the time, there are exceptions). The receiver does no decoding.
    Bit-Stream is an encoded stream sent to the receiver and the receiver does the decode.
    edited April 2009
    aljoseph wrote: »
    the best way to become De-bosed is to visit your nearest hi-fi shop and listen to anything else;)....
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2009
    I have a 5.1 set of "white van speakers". They're essentially a knock off of the Bose Lifestyle Speakers.
    I paid 65 dollars for the whole setup. A few months later, one of my friends bought an actual Bose Lifestyle system...I forget what he paid...somewhere in the neighborhood of 1500 dollars. We got it set up and listened to it for a while...
    My 65 dollar setup of white van speakers sounded roughly the same as the 1500 dollar Bose setup...possibly even a little better on the low end. Though my friend didn't want to accept it at first, he eventually admitted that my 65 dollar white van speakers sounded better than his 1500 dollar Bose speakers.
    So, what it comes down to, is if you want one of those teensy little cute Bose systems, just look for a guy in a white van. He can be found in the parking lot of places such as Best Buy or Fry's...outside of malls...any number of places.
    Box
    Of
    Shitty
    Equipment
    By the way, no offense intended to the OP here. Now get out there and get some better speakers!!...lol
    Welcome to Club Polk aljoseph.:)
    edit-We're almost neighbors...kind of...I'm from Dixon, IL about 45 miles south of Rockford. I used to hang out in Peoria a lot when I had friends going to school there.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Rocco1
    Rocco1 Posts: 190
    edited April 2009
    OP take a ride up from Peoria and go to the Fry's in Downers Grove and listen to the whole polk line. At least get your ears some sweet sound so you dont go hard of hearing listening to those BOSE. It will be about a 2 hour drive but well worth it. Heck maybe you can end up getting something.
    Man Cave: 7.1
    -PS Audio Power Plant Premier
    -PS Audio Power backup
    -Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
    > Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
    >Sub = MK Audio 10'
    -PS3
    -Onkyo 5 disc cd player
    -Directv
    -Samsung 59' plasma flanked by 2 Samsung 43' plasma's
  • aljoseph
    aljoseph Posts: 39
    edited April 2009
    Thanks to all who have commented here about Bose. I'm not knocking anyone or anything. The Bose systems I've had (and still have) served me well. For me, the over-riding decision to go that route in the 1st place was, and still is, my better half. Many moons ago, good quality speaker systems were huge. We lived in a small apartment then. No way was my wife going to allow that kind of a setup. We lived in New England (that's where we're from) not far from Framingham, MA. The decision to go Bose was a no brainer for us at the time. Well, times have changed. It's now time to try something better. You guys have any suggestions? ;-)))
    Pioneer SC-07
  • Hawkeye
    Hawkeye Posts: 1,313
    edited April 2009
    You can help yourself by letting the forum know several things. Ratio to music/movies, budget (the big question), how much room do you have, type of music you listen to, if any, etc. etc.....
    What exactly are you looking for? Just speakers or a combination of pieces? Are you willing to buy used or only new?
    Don't want to sound glib, but without that type of info you'll get recommendations all over the board and trying to sort it all out can become confusing.
    By the way, welcome!
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • aljoseph
    aljoseph Posts: 39
    edited April 2009
    Hi Gordon: Sorry to confuse you. I was being smart. If you read the whole thread there was some good natured kidding going on and I was just playing cute. I do appreciate your input. i am changing over to Polk Audio speakers and that's why I'm here and on this forum. I'm inheriting a pair of used RTA-8T speakers I purchased for my Son some years ago and I just purchased a used CSi 30 center channel speaker in the FS section. Still looking for more stuff to complete a setup. Al
    Pioneer SC-07
  • zingo
    zingo Posts: 11,258
    edited April 2009
    I would also looking into used prepros as well. I saw an Outlaw unit on the local CL for $150 which is a great deal. Add an amp and you will be set for a few years.
  • aljoseph
    aljoseph Posts: 39
    edited April 2009
    Hi Jake. Thanks for the comment. It'll take me awhile but I'll round up the necessary.
    Al - K1ELT
    Pioneer SC-07
  • erniejade
    erniejade Posts: 6,321
    edited April 2009
    I actually use a set of 301 for my fronts in my HT system. I also DJ and use an L1 system for the tops and a KV2 subwoofer with it. Everything has it's place in a way.
    When re-doing your system, if $ is a wory check out craigs list and look for some used stuff. It is a good way to try out different things. What a lot of us do on here is buy and sell. Welcome to the addiction!!
