Question about cente c volume
TO who have a HT do you set the center level higher than your mains.
Thanks in advance for the help.:)
TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX
AVR: Denon 3801
Sat: Directtv HD 10
Post edited by greg2350 on
Have you tried calibrating all channels with an spl meter? The beauty of it being your theater is you can then up the level a little to where it suits you....
I personally have mine a couple of db lower than the mains.In terms of audio, i truly feel sorry for the visually impaired. How can they know what they like if they cant read google?
http://www.polkaudio.com/forums/showcase/view.php?userid=86838 -
Back when I had a center I had it set a little higher. If the dialogue is muffled then bump it up.MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s -
Thanks for the responses I have my center +2 higher than the mains. I should get a better center I use the CS1 being powered by a rotel bridged 200 watts. my mains are RT8OOi's powered by rotel 180 watts. Sub is DSWpro 500. Rears are R50's powered by a rotel 150 watts. I find I need to turn up the center higher to hear the dialog, im sure a better center would help.:)TV: Philips 42" LCD 1080p
AVR: Denon 3801
Sat: Directtv HD 10
Center Speaker amp: Rotel 970 BX -
At one time I was using a CS2 with Rti10s in front and R50s in back. The level set by my Onkyo 875 Audessey (spelling?) Auto Eq was too low for me. At first I thought the center was just too weak to keep up with the 10s. To some extent that was true. However, once I increased the center level it was not too bad. Just because you have to turn your center up, it does not mean that you need a new center. Of course, I didn't *need* most of the gear I've bought over the last year. So if you *want* a new center it sounds like you have a legitimate reason
) MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
NewHT has it correct. Bump up the center if the fronts are overwhelming it. The center is a bridge between the L/R fronts. It should be largely transparent, with all three speakers working together to bring the sound focus to the screen. That most often happens during dialog.
