Differences in vintage Polk drivers
geppy1
geppy1 Posts: 3,076
edited April 2009 in Vintage Speakers
I have a question--Polk used the 6500 in the Monitor series prior to '83 and the 6600 in the RTA 12s prior to '84 Starting in about '84 or '85 they went with the one-fits-all 6501.
Why did they do this and what is the difference between these three?
Post edited by geppy1 on
  • zingo
    zingo Posts: 11,258
    edited April 2009
    Try running that by Polk CS. They could probably help you on the technical side.
    F1nut Posts: 51,686
    edited April 2009
    Perfecting/contouring the sound to fit the desired result.
    Each driver has different parameters, which may be slight or large depending on the results that Polk was after.
