Mounting speakers
ge11ings
ge11ings Posts: 12
edited April 2009 in Speakers
Hello. I just bought some speaker mounts (http://tinyurl.com/dklzxb) and in order to tilt them down the instructions say to use the safety screws. These are back surrounds rti6s. Using the safety screws means drilling at least three screws in the bottom of the speakers. Instructions (http://tinyurl.com/ccbjwt) actually say use five safety screws but only 6 came in box for two speaker mounts. So I'm guessing three on the bottom is okay.
My question is does anyone know if drilling the holes and using the safety screws can cause any negatives in speaker performance?
-Thanks
Post edited by ge11ings on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited April 2009
    ge11ings wrote: »
    -Thanks
    These are for BTech BT-77s.
    I use these as well for my fronts, which are RTiA3s - the successor to the RTi6.
    You do not have to drill holes if you do not want to.
    Instead, use zip ties looped thru the rear power port and secure them to the BT-77 brace:
    http://erikt.cts.com/Pictures/hometheater/RTIA3-Mount-2.JPG
    http://erikt.cts.com/Pictures/hometheater/RTIA3-Mount-3.JPG
    As you can see from the pics, I have my speakers tilted down as well - all is good and secure and snug - no holes in those lovely cabinets.
  • Intel92
    Intel92 Posts: 146
    edited April 2009
    Erik Tracy wrote: »
    Great info Erik. I've been looking for mounts for my RTi6s. I assume you would recommend these?
    Wayne
    Theater rig:
    Pio Elite Pro 111-FD
    Pio Elite VSX-01TXH
    Mains: RTi12s
    Center: CSi5
    Surrounds: FXi3s, RTi6s
    Sub: Velodyne V-1012-B
    Amp: Carver TFM-35
    Harmony 890
    PS3
    2-channel rig in progress:
    LSi15s
  • Erik Tracy
    edited April 2009
    Intel92 wrote: »
    Wayne
    Sure.
    Here's a shot from the front of my rig with the RTiA3 on the mounts:
    http://erikt.cts.com/Pictures/hometheater/home-theater-valor.JPG
    I used the BT-77s originally with my RTi4s, then for a bit, I had LSi7s up as well - which are heavier than the RTi6 - no problem using the zip ties in back to keep them in place.
    The square cabinet design of the RTi6 is better suited for the clamp design of the BT-77 anyway.
    The curved cabinets of the newer RTiA series gives less pinching area and so the zip ties are mandatory.
    Cheers,
  • ge11ings
    ge11ings Posts: 12
    edited April 2009
    So the ties go all the way from the bottom brace to the port. It's hard to tell from the picture. Do your A3s have just one mounting hole at the top of the port? The RTi6 has only one mounting hole at the top of the port.
  • Erik Tracy
    edited April 2009
    ge11ings wrote: »
    Yup - I run the zip tie thru the mounting hole at the top of the powerport on the back.
    I had to join a couple of zip ties to make a loop big enough to go thru the powerport mounting hole and down low enough to get close to the BT-77 support.
    Then I fasten/capture that loop from the powerport mounting hole with second tie wrap that goes around the BT-77 support member as in the second picture:
    Hope that made sense....:)
  • Ender
    Ender Posts: 603
    edited April 2009
    Lol. When I saw the title of the thread, my thoughts were "Man, that's a true audiophile right there."
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • superjunior
    superjunior Posts: 1,632
    edited April 2009
    great idea and great pics, ingenuity at its best. damn shame to drill holes in those puppies if you don't have to..
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • Erik Tracy
    edited April 2009
    Credit where it is due goes to McLoki, who first posted up his ziptie idea for his LSi bookshelves - I ran with that for my RTiA3s.
  • ge11ings
    ge11ings Posts: 12
    edited April 2009
    Erik what do you have around the support brace where the zip tie goes around? Is that just a piece of electical tape to keep the tie from slipping on the brace? Looking to finish mounting tomorrow...thanks for letting me know of the idea! :)
  • Erik Tracy
    edited April 2009
    ge11ings wrote: »
    Friction tape.
    Good luck with the project - keep us posted on how it works out....pass on the tips!!
