RT2000P's little light
Does anyone know if the little green light in the center of the RT2000P's are suppose to stay on all the time? or are they suppose to come on only when the amps have feed to them? Any help would be greatly appreciated.
Post edited by darruda on
i think olny the amp turns on when it has a sigonal.
HI:
The light stays on all the time. The amp will switch off when a signal is not present. I know, I have a pair.
Gary -
Yep mine stay on all the time too.
Yeah, those little lights bug me too. I'll walk through the living room where the 2000is live and see that one (but not both) of the lights will be on...and the system hasn't been powered up since the day before. I know they are only supposed to come on when the amp is receiving a signal. Sounds like I need to spend a bunch of money on one of those HT power centers....or some electrical tape.system 1:
Athena: AS-F1 mains, AS-C1 center, AS-B1 surrounds, AS-P400 sub, Yammie RXV-730, Rotel RB-976 driving front stage, Samsung BD3600 Blue Ray, Denon DVD2900 for sacd/cd , jbl n24awII on the deck, samsung 40" 1080p lcd
system 2:
XBox 360 Spherex 5.1 system, HK DVD38, Phillips CDC 926 CD changer, Phillips 32" LCD
2 channel
NAD 1600 pre, NAD 2400 THX amp, Phillips CDC 926, Linn extra speaks, crappy TT -
I love my Little Green Lights. Mine stay on all the time.:cool:
if i had a set of them i wold re wire the green lite so it comes on when you get sigonal to them.my parents onec had a sub with a led when the bass got louder it gloed brighter. that would be prety cool too.
what is the light size? 1mm, sheesh
take a hole punch and knock it out for gods sake and then you won't be bugged by the microscopic led light... Ok that was a jokeMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Polk resolved this issue with the new RTi line--no lights, no complaints, no electrical tape or rewiring necessary. The lights only bothered me when I first put a pair of RT1000p speakers as surrounds and one of the lights reflected off the TV screen. Sometimes the amps would click on if my dog would bark, but the lights would be on all the time in the auto setting. Same thing with the RT1000i speakers.
Thanks for all the info. It's not that I am bugged by the little lights, rather it was the fact I was trying to find out if they were suppose to stay on. It all started with my friend who has the RT2000i's, his light only comes on when his amp receives input. I thought my speakers were defective since my little green light stayed on all the time. Now, from all the input, I can see that my speakers are just fine.
Thanks again!:D -
ROFL.......very nice faster.......good lord....
What I'd like to do is to switch the lil **** from green to blue. Not that that would be subtle, but who cares.......comment comment comment comment. bitchy. -
Thats funny... when I had my RT1000i's..the little lights were on all the time..... but my RT2000I's lights only come on when i turn the stereo on..otherwise..no greeen light..hMMMMM
if you can find one with the right voltage then you might have to make the whole a little bigger to fit it in. caues blue led are few and far between. red would be alot easer to find.
I love the green LEDs in the center!!.. It's cool when you're watching an action DVD with the lights off. When the sounds starts pumping and you see that little glow, it gives you a sense the power the RT2000s are capable of.
Mine used to stay on too. I just unplugged it for a couple of secs. After that, I never had a problem with them not going off after there was no signal.Harmon / Kardon AVR 510
Fronts: RT2000I
Center: CSi40
Surrounds: FXi50 *waiting in box
Sub: PSW650
JVC DVD Player
Monster Cables -
The lights should only come on when signal is present. The lights signify that the internal power amps are powered up. The lights will stay on for several minutes after the signal has dissappeared.
If the lights stay on all the time you may have an earth loop inducing hum into the input ( I suppose your using the line level inputs).
Hope this helps.
