About a Harman Kardon preamplifier part.
Theodore41
Theodore41 Posts: 3
edited April 2009 in 2 Channel Audio
Hi all.
I have a old Harman Kardon preamplifier,model Citation 17,which seems that has a problem with a mode switch,(stereo,stereo rev,mono,right,left),#24025430.
I ask,if there is this switch as a spare part somewhere,so as to find it.
Post edited by Theodore41 on
  • Systems
    Systems Posts: 14,872
    edited April 2009
    What seems to be the problem with the switch? Is it indeed thew switch?
    Testing
    Testing
    Testing
  • Theodore41
    Theodore41 Posts: 3
    edited April 2009
    Yes,it is the switch,because when set to mono,plays OK,while on stereo,plays one channel only,and occasionaly plays again,OK,and if set to stereo rev,plays the other channel.
    Thank you for your response.
  • DollarDave
    DollarDave Posts: 2,575
    edited April 2009
    Have you tried cleaning it with Deoxit?
  • ViperZ
    ViperZ Posts: 2,046
    edited April 2009
    DaveMuell wrote: »
    Dave is right. There could be corrosion or some debris on the switch contacts. Most likely, the switch is not hermetically sealed, so you should be able to apply contact cleaner to the contacts (doesn't have to be Deoxit). Then just exercise the switch several times and see if it will help.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
    heiney9 Posts: 25,471
    edited April 2009
    DaveMuell wrote: »
    This most likely is the culprit............a dirty switch. Happens all the time and it doesn't take much contamination to cause your type of issue.
    Good luck
  • Systems
    edited April 2009
    Forget Deoxit. Look for a product called RID-OX from TECH-SPRAY. This works much better and will also protect as well as clean. Find it at www.techspray.com look under 'products' and select 'index' then scroll down to 2100-coatings.
    But it does sound more like just a dirty switch than a switch needing replacement.
    Testing
    Testing
    Testing
  • Theodore41
    Theodore41 Posts: 3
    edited April 2009
    Thank you guys,for your responses.
    I found a distributor in Greece of this Rid-ox,and I am going to try this product.
    Regards,
    Theodore.
