No E-Bay at work
Vette C6.r
Work just put filters on to block e-bay. I do, however, have access to CP.
Fair tradeoff ????
Fair tradeoff ????
Post edited by Vette C6.r on
you should ban yourself for even asking that question here when you already know the answer...
EBAY RULES!!!!:eek:
j/k:pThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Receiver: Marantz SR7002
Fronts: Canton Chrono 509 DC
Center: Canton Chrono 505 CM
Surrounds: Canton Chrono 502 SP
Sub: SVS PC12-NSD
TV: 40" 1080i JVC Multisystem LCD(upgrading to 50" Samsung LED)
Blu-Ray: PS3
DVD: Pioneer DV-420V (HDMI)(for PAL DVD's)
Audio/Music: MacBook Pro hooked up thru HDMI
Gaming: PS3 (oifvet0608) XBOX 360 (JAYtheVET)
Cables: Inakoustik Reference -
No luck oifvet - thanks for the info. Worth a shot.
I might have to actually do some work. -
Vette C6.r wrote: »No luck oifvet - thanks for the info. Worth a shot.
Can you set up a proxy server? If so you could get a linux VPS, install proxy software on port 80, and proxy everything through it.
W -
Wow Wizzy. You lost me. I have no access to change any proxy to my knowledge.
If I did I'm sure there would be some sort of wrist slapping going on. -
You get up in the morning and go to work. You don't get up in the morning and go to ebay. Its the rules there where you work. Don't like the rules? With evermore layoffs and downsizing going on these days I'm not so sure I'd try and press my luck.
Why am I on here at 8:21am EST? I own the company and make my own rules.Testing
Testing
Testing -
Are you hiring?:pYou get up in the morning and go to work. You don't get up in the morning and go to ebay. Its the rules there where you work. Don't like the rules? With evermore layoffs and downsizing going on these days I'm not so sure I'd try and press my luck.
Why am I on here at 8:21am EST? I own the company and make my own rules.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
nooshinjohn wrote: »Are you hiring?:p
Can you rebuild landing gear for aircraft? But there is NO ebay at work....LOLTesting
Testing
Testing -
I think I can handle that. I worked f/a-18's in the corps. All I need are the correct parts and the tools...
And so long as C/P is cool on rare occasion, I can live without ebay...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
nooshinjohn wrote: »I think I can handle that. I worked f/a-18's in the corps. All I need are the correct parts and the tools...
LMFAO
Do you do any business in Germany? I'm looking for a job when I get out of the Army. I do hydraulics on tanks...but I have alot of other skills.Receiver: Marantz SR7002
Sub: SVS PC12-NSD
Blu-Ray: PS3
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/HYokLWfqbaU&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/HYokLWfqbaU&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>Expert Moron Extraordinaire
You could always try a web proxy like http://www.hidemyass.com/ or something like it.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Try going onto ebay canada, just to get your fix. Thats what my brother does at his work seems to work just fine for him.Sig to be updated after dealing with the insurance company:(:(:(
