Sunfire Series 1 vs series 2
vmaxer
vmaxer Posts: 5,121
edited June 2009 in Electronics
Does anyone know what the differences are between the series 1 and series 2 cinema grand signature amps. I know the series 1 is 405 watts X5 and the series 2 is 425 watts X5....What else is different??:confused::confused:
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Post edited by vmaxer on
    nooshinjohn Posts: 26,000
    edited April 2009
    vmaxer wrote: »
    A great question... I have the signature 7/400 and love the performance of it... I do not know the differences between the different series however. That said I don't thing there is much of a sound quality difference in them.. I could be wrong however.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited April 2009
    Minor upgrades; some of the older amps hard wired power cord versus the newer ones with the removable cords.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • amulford
    amulford Posts: 5,020
    edited April 2009
    The differences are minor. Sonic signatures are the same.
  • vmaxer
    vmaxer Posts: 5,121
    edited April 2009
    Okay, It seems there really isn't a lot of differences, a few watts....the age. With that said, how much more is a series II worth?
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    edited April 2009
    I don't see to much of a price gap between the two, and IMHO don't believe there is enough of a difference to justify one. Are you buying one?
  • vmaxer
    vmaxer Posts: 5,121
    edited April 2009
    I bought a Cinema Grand 200X5 a while back and just bought a Signature Series II 425X5...I thought. When it arrived it is a Series I??? I don't know if it was an honest mistake on the sellers part or not yet. I also don't know if I want to return it and wait on a Series II or not??
    I bought the Signature Series because I have a pair of LSI 15's coming and all I read says the more power you give them the better. I am thinking of bi-amping the 15's with the Signature Series and using the 5th channel for the center speaker. I would then use the 200X5 for the surrounds.
    What do you think??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2009
    Sounds like a good plan. You will be giving the LSI's all the power they need to run to their full potential regardless of what series Sunfire you have.
  • TNRabbit
    edited April 2009
    As vmaxer said, there isn't a hill of beans difference between them other than age. Some very minor refinements. Little to no price difference, mostly due to age. These amps are damned bulletproof.
    TNRabbit
    Sunfire TG-IV
    edited April 2009
    they are UPS proof too...
  • vmaxer
    vmaxer Posts: 5,121
    edited April 2009
    UPS is unbelivable....I think the heavier the package the more they throw and drop them. Then they say the packaging wasn't good enough and deny the claim. They just cost me $284.00 on a CS1000p they destroyed. The amp was also handled very rough, but as nooshijon said they seem to take it well.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    edited April 2009
    I heard of one that got a forklift shoved thru the case by the aforementioned UPS and it still worked. They also denied the claim saying it was improperly packed.
    edited April 2009
    correct me if I am wrong here, but are there not three versions of the Sig series?
    Mk1 would be the 400wpc versions with an attached power cable
    Mk2 would be the detachable power cable @405wpc
    Mk3 would be the 425wpc version...
    do I have this right?
  • vmaxer
    vmaxer Posts: 5,121
    edited April 2009
    I certainly don't know, but I did call Elan and gave them the serial number and they told me mine was a series 1 405 watt X 5. I bought it as a Series II 425 X 5....I'm still not sure of how I am going to handle this.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • XJRGUY
    XJRGUY Posts: 258
    edited May 2009
    I thought the power supplies and caps were changed to larger capacity in the later units.
    See here for details
    http://www.hometheaterhifi.com/volume_6_3/sunfire-cinema-grand-signature.html
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2009
    XJRGUY wrote: »
    Thanks a lot, this information helps!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • TNRabbit
    edited June 2009
    Thread revival....
    That was one I sent; they didn't deny the claim because they couldn't; THEY packaged it! Paid to ship it back to Sunfire, put a new top on it (the LAST ONE Sunfire had), and ship it back to the new owner in Maine.
    TNRabbit
    Sunfire TG-IV
