LSi9 Stands -- Thinking VTI UF, opinions?
wizzy
wizzy Posts: 867
edited April 2009 in Speakers
Anyone use VTI stands?
Shelf rated @ 100lbs (!)
One column fillable
Generous size top plate @ 6.5" W x 8" D
http://www.racksandstands.com/VTI-UF-VI1047.html
Looking at 29" in silver
Post edited by wizzy on
    F1nut Posts: 51,997
    edited April 2009
    You get what you pay for. In their case, cheap junk.
    A friend of mine recently wanted some stands for a pair of speakers he hadn't used in awhile and asked me to see what was available for the requirements needed. I found choices from VTI, Sanus and Skylan. He decided to go with the cheapest price and had me order a set from VTI. My first impression was how cheap the the packaging was. My next impression was how poorly made they are. It seems the paint chips easily as there were more than a few on the base plates. The welded plates inside the top of the columns were not evenly done and once assembled the top plates didn't sit square with the base. One of six screws used to attach the top plates was missing from the sealed bag and one of the screw heads was slightly smaller and a slighty different color than the others. On the top of the base plates is the company logo, which were attached in different locations on the two stands. All in all, nothing but junk, IMO. However, my friend isn't picky and didn't really care about all the build issues. He also didn't care that metal is the worst choice of material for speaker stands.
    On the other hand, I'm very picky and fully understand what makes a good speaker stand, so I bought mine from Skylan. They arrived well packaged and the assembly was a breeze as the design is simple, but ingenious. The fit and finish is flawless. As the stands have to be mass loaded, they even supplied a cup and paper funnel...a nice touch.
    http://www.skylanstands.com/stands.htm
  • sir_lagzalot
    sir_lagzalot Posts: 258
    edited April 2009
    I have a pair of Bello SP-200 and I love them, I have the black ones but they come in titanium as well.
    http://www.racksandstands.com/Speaker-Stands-C97.html
    ****Home Theater****
    Integra DHC-40.1
    Rotel RMB-1075
    Fronts 265-RT
    Center 265-RT
    Rears 65-RT
    Sub BIC H-100
    ****VIDEO****
    Projector Epson 8700 UB
    BLU-RAY Sony BDP-S1000ES
    ****2-Channel****
    Magnepan SMGa
    Sub ED A3-250
    AMC 3100a
    TT Music Hall 2.2
    Bellari VP 130 Phono Pre
    Grant Fidelity Tube DAC-09
    Sirius Stiletto 2
  • wizzy
    wizzy Posts: 867
    edited April 2009
    Interesting ... saw a lot of good comments on VTI products out there.
    The pics on the skylan website look metal. Is that MDF?
    F1nut Posts: 51,997
    edited April 2009
    The tops and bottoms are MDF, the columns are a thick plastic....zero ringing. Everything is sprayed with a slighty textured catalyzed satin black lacquer. Again, you have to mass load the stands. I used 25 lbs. of leadshot per stand and might add some sand later. The other great thing about Skylan stands, you can order the plate size and column height in just about any size you want.
  • Ender
    Ender Posts: 603
    edited April 2009
    Yeah, the first thing I noticed was that those stands in the OP were metal... and I ended up facepalming myself. I need to stop that.
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • dougy
    dougy Posts: 182
    edited April 2009
    Those Skylan stands look like they would be really good. I'd never heard of them. I like my Sanus SF30's, especially since they were only $120 from Parts Express, but if I'd seen the Skylans first, I may have tried a pair.
    THE MAN-CAVE 5.1 CHANNEL A/V RIG
    Sony KDS-60A3000
    a/d/s/ HT-400LCR (3)
    a/d/s/ HT-300 (2)
    Velodyne DLS-4000R (2)
    Pioneer Elite VSX-55TXi
    Pioneer Elite DV-47Ai
    Sony BDP-S300
    Sony SLV-779HF
    DirecTV HD sat. receiver
    MAN-CAVE 2-CHANNEL RIG (shares sources with a/v system)
    Adcom GFA-5500
    Bose 901 Series VI
    NAD C-165BEE
    Slim Devices Squeezebox Classic
    TEAC CD-RW890
    Technics SL-BD20D w/ Audio-Technica P34
    Akai HX-A3X
