How to use Zerostat 3
thsmith
thsmith Posts: 6,082
edited April 2009 in 2 Channel Audio
A friend gave me all his old DIscwasher stuff which includes a Zerostat 3.
I get a slight shock with it so I believe it works. How do you use it on an album?
Thanks,
Tracy
Post edited by thsmith on
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited April 2009
    It's been 25 years since I used one, but from memory, this is what I recall.
    Hold the gun 10" to 12" above the record. Slowly (2 to 3 seconds) sqeeze the trigger, then release the trigger just as slowly. Do this in 3 or 4 places around the record.
    Maybe someone has the original instructions to confirm.
  • Fongolio
    Fongolio Posts: 3,516
    edited April 2009
    ^^^That is exactly how I use mine.^^^
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • thsmith
    edited April 2009
    Thanks guys !
  • thsmith
    edited April 2009
    One more question. Am I suppose to leave this cap on or off ? The cap appears to have a bulb of sorts that lights briefly when I pull trigger fast and release fast
    Toolfan66 Posts: 18,152
    edited April 2009
  • thsmith
    edited April 2009
    so if the bulb lights you are releasing ions ?
  • WilliamM2
    edited April 2009
    The cap is just a tester, to verify the unit works when you pull the trigger. It is supposed to be removed for actual use.
    edited April 2009
    WilliamM2 wrote: »
    Really!!! i need to look at the instructions again. now i feel stupid:p
    If i gave you the wrong info OP i am sorry.
  • WilliamM2
    edited April 2009
    Wow, they still make these things. Although they are made in China instead of the UK, and have gone up from $20 to $100!
    Anyways, here are some instructions that mention the testing cap.
    http://www.2spi.com/catalog/photo/useinst.html
    If you don't remove the cap, you will be grounding the electrode with the bulb, and it won't do anything.
  • thsmith
    edited April 2009
    Thanks, I was hoping someone had actual instructions.
