which one?
edited February 2003 in Car Audio & Electronics
which is better the momo mm124 r the momo mm120 for 12" subz? how bout the component wat is better r wat is the differentz between the mm6 and the mm465?
Testing
Testing
Testing
    i think the new momo is better than the older one... its a 2nd generation sub, thus you'd expect the bugs of the first to be worked out... and i really do think they improved it.... having heard both i'd be chasing the new model.
    the components are almost identical i think.
    The Artist formerly known as PoweredByDodge
    check out the "new momo" post at the top of the forum
    its a sticky
    it should answer your questiona bout the components
    i had the same question
    -Cody
Welcome!
Welcome!
