Are They Better?
CLPolk
I knew this was going to happen when I bought the 2's My first pair of polks SDA 1A I bought for $200.00 about 10 miles from my house! My second Pair were SDA SRS 2's I paid $600.00 and drove 1000 miles round trip! When I listen to the 1a's I think to myself WOW!! they sound Great for $200 and I love them! But when I listen to the 2's I allways think to my self are they really worth $600 Are they that much better?
- SDA SRS 2
- SDA 1A
- Monitor 11
- Monitor 7B
- CS350lsi
- RM-6600
- FX500i
Post edited by CLPolk on
What amp are you using?
I assume the srs would need more wpc than the 1a's to bring out their best.2 Channel
Amp - Jas Audio Bravo 3.2 set
Power Cord - Tunami GPX
CDP - Marantz cd6002 - Audio gd Ref 5 Dac
Speakers - Tekton Lore,Polk Audio RTA11tl completely refreshed. -
I have the 4ohm B/B and and power them with a Yamaha DSP A2070 80 watts I will be getting a Carver PM 1.5 amp 600watts @ 4ohm soon It should make a differnts I hope
- SDA SRS 2
- SDA 1A
- Monitor 11
- Monitor 7B
- CS350lsi
- RM-6600
- FX500i
The amp should make a huge difference. Let us know.
you would be better off too get tfm series instead of pro series amp.home stereo versions will sound better
mewisemagic wrote: »you would be better off too get tfm series instead of pro series amp.home stereo versions will sound better
Agreed,the stereo versions should sound better.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Why? Aren't the bigger speakers even more efficient than the smaller ones? If I'm right about that, the bigger speakers would need LESS power at the same volume level. The bigger speakers may ACCEPT more power; but the point would be to play 'em louder.
Now, the "nominal" ohms rating may--or may not--make life harder on the amp by pulling more current--but--if you have a 4-ohm-rated amp...life should be good.
More watts = louder, not "better". -
Your right! I should have explained myself better.:o2 Channel
