Zarrdoss
Toolfan66
Kevin,
Thanks for letting me come by and hangout and listen to your system.
Had a great time b/s about your speakers, You did a fantastic job refurbing the 2.3tl's they sound great with a small budget system none the less.
Sorry i did'nt take the 2.3's off your hands, as i am looking at getting the SDA SRS 1.2's or 1.2tl's.
Anybody looking to deal with Kevin, no worries he is a stand up guy to deal with. he has more Knowledge about these speakers then i do that is for sure.
Thanks again Kevin.
when i get the 1.2's you will have to make a trip down my way then you can hear the RTiA9's as well.
Thanks again Kevin.
Post edited by Toolfan66 on
definitly get the 1.2 tl's
I liked the 2.3TL's better than the 1.2TL's.
