RDO 194 upgrade for SDA SRS 2.3, anyone?
zarrdoss
has anyone done the RDO 194 upgrade for the regular sda srs 2.3? if so, how much of a difference overall did it make? would a pair of reg 2.3 with the rdo and x-over upgrade come close to a regular pair of 2.3tl's?
Post edited by zarrdoss on
Do the x-overs at the same time. Haven't done it yet, read nothing but GOOD about the RDO's.Onkyo TX-SR705 AVR
Onkyo M-501-Given to my father.
Onkyo DX-C730 CD Changer
Onkyo DV-BD507 Blu Ray player
Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
Polk Monitor 12's with RDO's and XO's
Polk CS300 Center
Polk Monitor Series 4 rears
EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek: -
Yes, I believe a number of folks have done that upgrade. Have you tried the search feature?
From my personal experience, although not with your model, the new tweeters make a huge difference.
No, different tweeters, different drivers and different cabinets.Political Correctness'.........defined
President of Club Polk -
I have upgraded to rdo 198 in my 2.3tl but those had 3 blown tweets when I got them so I didnt really know the difference, I had a guy come look at my reg 2.3's yesterday and when compared to my 2.3tl's they did not sound as good and he was wondering if those mods would make them sound as good as the 2.3tl's. I dont know I like the way they both sound, now that I did a side by side the tl's definitly sound better though.
Thanks for the info though. -
The RDO 194's made my SRS 2.3's much smoother and I was able to distinguish more space between the instruments at the higher frquencies. I was very satisifed with the results. Don't forget to add the dampening materila to the baskets of the woofers and maybe some Mortite in place of the paper gaskets. The sound will tighten up and provide better clarity and definition. The Dynamat and Mortite upgrade might cost $35. A great investment. Use the Forum search engine, there is a lot of infor on theis subject. An upgraded interconnect between the two speakers also helps with the SDA separtion. This upgrade may cost $50 or less. My point is a little investment can go a long way. Spending $350 on a crossover upgrade will give you a nice SQ improvement, but there are other less expensive tweeks to be done. Have you mounted your SDA's on spikes?Carl
well the ones I have are on a hard floor and the others I need to make some spikes at work:D
if they dont sell, speaking of work........
