Wierd popping noise?
Systems
Help me! I installed my two 12inch MOMOs and one of them makes a weird popping noise. Is it blown or what? I bought the subs though a "discount" site brand new and I don't know where to turn to. What can I do?
Testing
Testing
Testing
Testing
Testing
HEY MIKE WASS-UP! ON MY POLK DB-10'S I HEARD A NOISE, WHEN I INVESTIGATED, THE SUSPENSION MATERIAL AT THE BOTTOM OF THE CONE, INSIDE THE WOOFER HAD COME UNGLUED. MY CAR HAD A WATER LEAK AND SOAKED THE BOX. I THINK THE HI HUMIDITY AND HEAT HELPED THIS HAPPEN. I WAS ABLE TO REPAIR IT WITH SOME ADHEASIVES I HAD AVAILABLE AT WORK, AIRCRAFT STUFF! WAALLAA, NO MORE NOISE. HEY ITS A TRY! GOOD LUCK NOISE HUNTING.
HEY MIKE WASS-UP! ON MY POLK DB-10'S I HEARD A NOISE, WHEN I INVESTIGATED, THE SUSPENSION MATERIAL BETWEEN THE CONE,AND THE MAGNET OF THE WOOFER HAD COME UNGLUED. MY CAR HAD A WATER LEAK AND SOAKED THE BOX. I THINK THE HI HUMIDITY AND HEAT HELPED THIS HAPPEN. I WAS ABLE TO REPAIR IT WITH SOME ADHEASIVES I HAD AVAILABLE AT WORK, AIRCRAFT STUFF! WAALLAA, NO MORE NOISE. HEY ITS A TRY! GOOD LUCK NOISE HUNTING.
