Configuring the Amplifyer's LFE and Gain
kanazky
Hey Everyone
I am wondering about how to get a good crisp bass sound from my subs without all that BUZZZZZZZZZZZZZZZ noise in most rap songs. Its really upsetting
My Gain goes from: 0.4A - 6.5
LFE Goes from: 40hz - 240hz
They are Knobs
Its a Pioneer GM-7200 - 800W Mono Amp
and I have 2x Kenwood 12" Subs
And my car is a Stock CIVIC DX-G 2007 Coupe 2DR (Stock Deck)
I was wondering the best LFE and Frequency for your usual rap music, so you get a nice crisp pound sound without the dragging on.
They are Knobs
Post edited by kanazky on
1. The sub amp gain should be at about 12'oclock
2. The LPF should be at 60-80hz
Try above and see if its better. -
Arun's starting point for the filter is good. Let me know if you have a multimeter, this is a useful tool for setting your gains. If you do not have access to a multimeter, doing it by ear will work. Turn all controls to their center position, get a good cd, turn your gain down, turn up the volume on the hu to 75% of max. Now star turning the gain up till you begin to hear distortion, at this point back up your gains just a tad till the distortion is gone. You should be pretty good at that point.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin
