RT10's
edited April 2009 in Troubleshooting
My friend has a pair of the polk audio RT10's and the midbass woofers in both speakers are shot.they are a 7 1/2" driver. i'm sure they can be rebuilt but. does anyone know where i can get used woofers for this speaker or if any company makes a woofer this size with the same specs and how much they would cost.
Post edited by stetson69 on
Welcome!
    edited April 2009
    You can order them direct from polk. Just call the number at the top right of the site. Tell them you are a club polk memeber, and you will get a discount and free shipping.
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS3(games/media server)
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    When rapture comes, can I have your car?
    edited April 2009
    thank you. i did ask them if they made new woofers for the RT10's and they guy told me they dont make those size woofers anymore for this model. . i'm sure they will repair them for an arm and a leg tho.
    edited April 2009
    Maybe someone else with more knowledge will chime in. If they aren't available through polk and the internet searches come up with nothing, then you can always find a midbass that would fit, it just may not be a polk. Try partsexpress, or madisound. You will definitely be able to find something that would fit, but the sound will be a hit or miss. There are many options, you just need to measure the speakers to find the right size. Both sites list driver dimentions. Good luck
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    edited April 2009
    thank you. i looked at partsexpress and they have no 7 1/2 woofers nor does madisound. polk audio told me i could use and 8' woofer but would have to do sum cutting but i'm not going to do that. is there a way to get the 7'' woofer to fit?
    edited April 2009
    There's no way to do it without modification of some sort. It would be much easier to make the hole bigger than to fabricate some sort baffle/bracket to make a smaller speaker fit. I would also double check the measurements on the woofer. Many companys have different ways of measuring, so company A's 7.5" woofer may actually be the same size as company B's 8" woofer. Look at the pdf specs and measurements listed on madisound or PE's websites. You will notice that all 8" or 7" speakers are not actually the same size. It will take some time, but there's a good chance you can find one that will come close to fitting. However, just because it fits, doesn't mean it will sound good. This may be a good time to wash your hands of this project and find some good used gear that works, since this one may turn out to be more trouble and money than the end result is worth. Good luck!:)
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    edited April 2009
    I have 2 for sale check my add in the flea market.
    Part# RD-7217-1
    thanks jerry
    Main- GTP-500II,GDC-600,GFA-555II and energy C-500s
    Basement-Audiosource pre/tuner,GFA-545,Onkyo
    DX-1400 and RTI10s
    Garage-GTP-450,onkyo M-282 and R50s with RTi55
    drivers and X-overs.
    My baby 18' V-king Mod VP with a merc 2.4 BP.
    KTM 620 Supermoto
    edited April 2009
    this is to hydrostream. how much do u want 4 the mid bass driver?
    edited April 2009
    Look at my add in the for sale section.
    jerry
    DX-1400 and RTI10s
    KTM 620 Supermoto
Welcome!
Welcome!
