Pre or no pre?
NotaSuv
Any benefit in going from a cd player to a dac to amp or going from cd to dac to pre......or better just to upgrade the source and go right to pre to amp...looking for a dedicated system 2 channel using a cd player..nothing set in concrete at this time...have read pros and cons on both setups just looking for alittle more advice from those that know ALOT more than clueless me..thanks
yes I realize that not every dac is capable of that.....and yes I realize those dacs cost a bit more....
Post edited by NotaSuv on
I don't know. Depends on your listening habits. Going w/o a pre amp or strictly passive has advantages, but one disadvantage I've found running in passive (straight from input to output) is you are totally at the mercy of the recording a bit more than if you had a pre-amp in the mix. Even the best active preamps add a bit of flavor here and there.
I have certain recordings I run in passive and others need the little bit of "sparkle" and dimensionality the active setting provides. Granted they are very similar but a slight difference can be heard.
I say try it using both and see which you prefer. Going w/o a pre or strictly passive is a love/hate thing. I like having the flexibility of both.
I assume you are feeding the digital out from CD to DAC. If your DAC has analog volume adjustment and you can hook up to an amp, I think it's probably easier and sounds natural than adding another pre in the mix. I think less components means simplicity and less color added to the sound (also less I/C). If you want to have tubey sound, you can add a Tube pre line stage in the setup later. But I would try without Pre first if your DAC has a good volume control.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
Passive is more transparent, but can sound thin with some setups. It depends on the gear, speakers, room, and listener preference."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Speakers would be a pair of like new Mirage M-1's with new crossovers, amp is a Proceed hpa2, still up in the air as far as a transport and dac, or a better player and a pre....going to listen to a few different setups this weekend..thanks for the input
How about a benchmark DAC-1 http://www.audiogon.com/cgi-bin/cls.pl?dgtlconv&1244236244&/Benchmark-DAC-1SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
I have the Benchmark Dac1 Pre, and when I first purchased it I connected it directly to the amp (Cambridge-Audio 840W). Worked great.
However, I knew I was going to be purchasing an SACD player with XLR output, and the Dac1 only had 1 set of RCA analog inputs. A secondary problem was the Dac1 had no remote control (to be remedied on 4/20), and it is bright as a super nova when the lights are low, or off.
So, I purchased a Cambridge-Audio 840E pre-amp, which has 2 sets of XLR inputs, remote control, and the ability to dim, or turn off, the lights.
I tried and tried, but I could not hear any differance between having the Dac1 going directly into the amp, versus going into the pre-amp, and then onto the amp. So, I am happy with the setup, plus the 840E/840W look better together than the Dac1 and 840W. Of course, that is my opinion.
Here is a pretty good review of the 840E/840W combinaiton.
http://www.avguide.com/review/tested-cambridge-azur-840e-preamplifier-and-840w-power-amplifierLumin X1 file player, Westminster Labs interconnect cable
