MIT Icon connections
first capital
first capital Posts: 100
What are the nuts for?:confused:To be used as a jam nut? How about the extra metal on the cable side that sticks out past the spade? For solder?
    F1nut Posts: 52,243
    edited April 2009
    Yes, jam nuts. I'm not sure what you are asking in your second question. There should not be any extra anything sticking out past the spade.
  • dorokusai
    dorokusai Posts: 25,625
    edited April 2009
    It's for spring clip connections. He means the stub after the threading F1.....is my thought.
    F1nut Posts: 52,243
    edited April 2009
    Ah yes Mark, got it.
  • dorokusai
    edited April 2009
    I think if you have spring clips and are using MIT cables...you might be going down the wrong path.
  • first capital
    edited April 2009
