Subwoofer Stackables?
MxStYlEpOlKmAn
MxStYlEpOlKmAn Posts: 2,116
Could I stack a SVS on top of the M&K? eh?
Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
Post edited by MxStYlEpOlKmAn on
  • PETERNG
    PETERNG Posts: 918
    edited February 2003
    Sure you can, probbably is the best way to handle two subs, you must carefully adjust the phase control therwise you may not hear any difference or improvement of your bass.
  • MxStYlEpOlKmAn
    alright, thanx
    I promised myself
    Damn you all! - ATC
  • Tour2ma
    Tour2ma Posts: 10,177
    You kinda like playing with blocks there SId?
    More later,
    Tour...
    Vox Copuli
  • MxStYlEpOlKmAn
    goo goo ga ga
    I promised myself
    Damn you all! - ATC
  • Dr. Spec
    Dr. Spec Posts: 3,780
    It's about 20" in diameter. If you place it on a hard smooth surface, it may bounce around a bit. The fix is to use 3M polyurethane feet (available either through SVS or Parts Express). They make the baseplate a little squishy, but it keeps the sub from moving around.
    On a carpeted surface, it's not an issue - even on most smooth surfaces it's not an issue. On slippery laminate, it's definitely an issue.
    The reactive forces from the driver are quite strong, and the addition of the amplifier on one side of the enclosure throws the concentricity of the forces off the vertical axis and introduces a horizontal component to the force vector and the sub can "walk" at high volumes.
    Wouldn't want it to "walk the plank" right off the edge of your M&K. :-)
    SVS
  • MxStYlEpOlKmAn
    LOL! No we wouldnt, Im pending on whether to get one or not - If I do, it'll be an extra to get. Im running into one big problem, I need to upgrade my computer (its my next in line) then i gotta save for a car audio stereo, and to fix up my dad's truck when it is in my posession. We'll see how the cards play and the dices roll
    I promised myself
    Damn you all! - ATC
  • Tour2ma
    Sid, I think you're approaching a plan a day here. What happened to getting the Adcom into play?
    BTW... nice system pix and love the quotes...
    More later,
    Tour...
    Vox Copuli
  • MxStYlEpOlKmAn
    i am just searching, next up to buy -- new receiver, 2 adcom amps, upgrade computer
    I promised myself
    Damn you all! - ATC
