LSI 25's Vs. 15's
Ok quick questions...I just hooked up my 25's and they sound awesome! Im not getting much from the powered sub.....do you think the 15's would sound better for HT and buy a sub in the future??? Or just wait a few more days???
TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Post edited by bdtae5656 on
Never had a set of these but did you run a cable to the LFE input from the sub out on your AVR?Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
thuffman03 wrote: »Never had a set of these but did you run a cable to the LFE input from the sub out on your AVR?
No not yet....I wanted to wait and hear both before I didTV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables -
You have to run a cable to the lfe input on your 25's in order for the sub to work, that is why you are not getting anything from them.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
Hey Pepi was there a big sound diffence when you updgraded the XO in your 15's
Which input does the Subwoofer(Rca) cable need to go in? Lfe in, out, etcTV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Coming in late to this - so keep that in mind....
1. - do you have the jumpers between the terminals on the back of the speaker? If no - you won't get any bass with just speaker hook ups. If yes, don't connect an RCA cable to any input.
2. - If you are using the subwoofer output on your AVR (or pre/pro) you want to use the LFE inputs on the speaker. (this will bypass the crossover in the speaker)
I personally like option 1 (especially if you have other subs in the mix) but thats just me. If you do choose option one - in the AVR - set your front speakers to "large" and sub to "off" (if you do not have other subs in the mix)
If you choose to use option 2 - make sure speaker is set to "small" with sub to "on".Mains.............Polk LSi15 (Cherry)
