Head Unit
Systems
Systems Posts: 14,873
edited February 2003 in Car Audio & Electronics
I am looking to purchase a new head unit. I can spend around 500 on it. I am currently running an old alpine deck and like it a lot it is just startin to go though. I have 3 JL audio amps and momo comps and subs. Any help would be great. I would really like a head unit without an internal amp.
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    well.... for a few weeks there i had been all hepped up on that pioneer deh-p7400 because it played mp3's and had soem nice toys and did everything my older alpine does and more.
    then i saw the new alpine cda 9815 and my whole mind changed -- if i hadda buy a deck today -- that'd be it... im almost hoping my 7864 breaks...lol.
    The Artist formerly known as PoweredByDodge
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    my favorite 3 brands of radios are alpine, eclipse, and pioneer
    chances are if its not one of those 3 brands...you probably couldve got something better
    -Cody
  • sntnsupermen131
    and for $500
    the 9815 is what i would do with
    totally awesome radio
    you can even go their website and burn information thats custom to your car and put it in the radio and itll save it for you
    but im pretty sure it does have an internal amp
    its hard to find them now that dont
    the other pioneer one he was talking about is cheaper though
    but it doesnt have all the cool accessories
    pbd,
    a long time ago you talked about a radio brand
    it started with a n i think
    you said it was really expensive
    i think it was you
    do you know what im talking about?
    if you do can you tell me that name again
    ive been looking around for head units
    probably going to buy one in the summer
    ive been looking at the pioneer premier 940
    pricey but on paper is awesome
    have you heard anything about it?
    it has 6 volt pre outs
    thats a lot
    some of the specs:
    Built-in DSP with PRO Mode
    13-Band Graphic Equalizer
    Frequencies: 50, 80, 125, 200, 315, 500, 800, 1.2k, 2k, 3.15k, 5k, 8k, 12.5k
    Level: +/- 12dB
    5 Factory and 2 User EEQ Presets: Super Bass, Powerful, Natural, Vocal, Flat,
    Custom1, Custom2
    Source Custom EQ memory (Independent Custom Memory for each source)
    Selectable Loudness Control (Low/Mid/High/Off)
    Auto-EQ (3 Curves, Microphone Included)
    Digital Sound Field Control (4 Presets)
    Octaver Bass Enhancement (2 Modes)
    BBE (+/- 4 Step)
    Time Alignment (4 Modes, 1 Custom): Adjustment range 0-160inch/1 inch steps
    Digital Automatic Sound Levelizer (ASL) with Built-in Microphone (5-Mode)
    Two-Way Crossover Network (Normal Mode)
    Front HPF: 50/63/80/100/125Hz, Slope -12dB/oct
    Rear HPF: 50/63/80/100/125Hz, Slope -12dB/oct
    Subwoofer LPF (Mono): 50/63/80/100/125Hz, Level -24 to +6dB, Slope -18dB,
    Phase (Normal/Reverse)
    Three-Way Crossover Network (PRO Mode)
    High HPF: 1.6k-20kHz, Level -24 to +0dB, Slope -12 or -6dB, Phase
    (Normal/Reverse)
    Mid LPF: 1.6k-20kHz, Level -24 to +0dB, Slope -18/-12/-6/0dB, Phase
    (Normal/Reverse)
    Mid HPF: 20-200Hz, Slope -18/-12/-6/0dB
    Low LPF (Mono): 20-200Hz, Level -24 to +6dB, Slope -18/-12/-6dB, Phase
    (Normal/Reverse)
    IP-Bus System Control
    MCD Control
    TV Tuner Control
    Auxiliary Input (CD-RB10 or CD-RB20 required)
    2 External Unit Control
    S.L.A. (Source Level Adjustment)
    Selectable Fader Control
    Hi-volt RCA Preouts (x3 pair, Front, Rear & Sub) (6V)
    the web site is here if you want to check it out
    -Cody
  • PoweredByDodge
    the pioneer premier is frickin nice -- i mean for christ sake its got digitally adjustable BBE... more more can a man ask for. Thats the pio i wanted to replace my alpine -- then i saw the 800 dollar price tag and started lookin at the 7400.
    The other heads I was talking about were probably Nakamichi. I've only seen 2 personally... they really are SQ decks... and they are priced like it too. If you can afford the alpine F1status... then u can afford Nak...
    the thing is though, like most upper end SQ decks... features are very lite... there isnt' much internal processing, not many toys at all... its expected the user is going to have outboard EQ's and Xovers usually.
    the emphasis on the deck quality is usually on laser / tracking precision, signal to noise ratio, often a copper chassis, and other such stuff like that.
    honestly i think alpine and pioneer make enough good decks between them to keep us non-multi millionaire / non-want to buy 500 bucks in outboard processing types happy.
  • Systems
    what about the alpine 7995 iit has no internal amp and a lot of features and is getting cheaper
    Testing
    Testing
    Testing
  • radicalG20
    radicalG20 Posts: 2
    I'll sell you my pioneer 9400 for $500. Let me know if you're interested.
    Jacob Barnes
    chameleon G20
    polk/momo sponsored
    more fiberglass than you can shake a stick at
