TUNE up CARS?
doggie750
doggie750 Posts: 1,160
edited April 2009 in The Clubhouse
How often do you normally do this, can u recycle the rotor/ distributor caps by simply cleaning it. Do you really have to replace the ignition wire? I guess I am a cheapo.....:o
NAaH.....i'll rather spend my time tuning my HT gears:)
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
Post edited by doggie750 on
  • greg2350
    greg2350 Posts: 544
    edited April 2009
    Yes I have done this many times I use steel wool if the contacts are worn to much then you will have to replace.
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
  • Pauly
    Pauly Posts: 4,519
    edited April 2009
    if the wires are dry rotted you will want to replace.
    Life without music would
  • Joe08867
    Joe08867 Posts: 3,919
    edited April 2009
    I have gone the route of cleaning the contacts on the distributor but I always replace the rotor and wires. Especially if there is any signs of dry rot on the wires.
    Just look out for burns on the distributor.
  • Face
    Face Posts: 14,340
    edited April 2009
    Cars still come with caps and rotors?
  • WilliamM2
    WilliamM2 Posts: 4,781
    edited April 2009
    I replaced the cap and rotor on mine, it's only about $15, and according to the manual, good for 50,000 miles. The last couple of cars I have owned, came from the factory with silicone wires, never had to replace them.
  • Jeb85
    Jeb85 Posts: 39
    edited April 2009
    For the price of parts it is worth putting all new parts on when you do a tune up. I have seen many cars come back that just had plugs replaced. In my opinion just replace the cap rotor wires and plugs. Cap and rotor usually come together and are cheap.
  • Systems
    Systems Posts: 14,873
    edited April 2009
    For the cheapo route you can clean the contacts on the cap and rotor. BUT these do have a gap just like a spark plug and the transfer of energy between the two will screw with the timing to a degree and the faster it turns the more it will screw with the transfer as in a weaker energy flow. Wires will breakdown resistance over time. These may look fine and appear to be in great shape but may be lacking the ability to deliver the spark also. Spend the money on the parts or pay for it at the pump. Your car/truck may seem to run smooth and drive fine, but I'll bet you are not getting the full potential from the engine.
    Testing
    Testing
    Testing
  • fast1
    fast1 Posts: 27
    edited April 2009
  • wizzy
    wizzy Posts: 867
    edited April 2009
    Don't forget to adjust your points & replace the condensor! :D:D
  • Systems
    edited April 2009
    wizzy wrote: »
    Set points dwell BEFORE timing. Be sure to disconnect the advance vacuum line to the distributor first. Then reconnect and check for total advance at spec'd rpm. Never rely on a fancy advanced timing light. I like to stick a piece of solid core wire inside the boot of the plug wire to the #1 spark plug and hold the other end close to the timing pointer to allow for an arc of the spark to light the timing pointer. This way you don't have to allow for the speed of light to reach the timing pointer.
    Test the condensor by loading it first with a charge from the battery. Then toss to a friend and have them catch it. If they yell and start chasing you then the condensor is actually fine. But you'll probably need to replace it anyway since said condensor is now lost in the battle that will surely result from the test. This is where the old spak plugs come in handy as you can actually recycle them by throwing them at your attacking assistant.
    Testing
    Testing
    Testing
