**** up majorly with speaker selection
larrykwiat
I recently bought a rm6200 package (rm1300 satelites and a rm1600 center) and a psw303 subwoffer to go with my yamaha htr-5560 receiver.
this is an entry level setup but for my ears sounds pretty good. I was browsing ebay and this guy is selling stuff pretty cheap. so I bid 100 bucks on a csi30 center speaker and get it. Now I am stuck with what to do:
1. use the csi30 as the center speaker and use my old center speaker (rm1600) as a rear center speaker.
2. sell my rm6200 package and get better satellites. What satelites would you recommend.
The basic question is will the csi30 which is a way better center speaker than the rm1300 satelites work allright or will it overmatch them....
I really appreciate your time and effort in understanding the question and commenting. I know some of these questions are really involved. thanks in advance
Post edited by larrykwiat on
Try number 1, if YOU like the sound, you are all set. If you don't like it you can try #2, or resell the csi30 on ebay. I hate to say it but sometimes you just have to experiment.
