POlk Audio psw110 and 125
royalty
royalty Posts: 246
edited April 2009 in Speakers
Are these subwoofers any good or no?
HOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around
Post edited by royalty on
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited April 2009
    What is your set-up, good subwoofer but what do you want to do with them? I use the PSW110 in a moderate size HT room (13x22) and it sounds good (however thinking of possibly adding a second one). If your room is larger than mine, you might want to consider the PSW125 or is you want lots of bass punch, maybe consider the 303, 404 or 505... Pricing are going down on those older models so you could get larger for the same investment (looking at your gear, you might want to use larger than 110).
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • vijayl
    vijayl Posts: 258
    edited April 2009
    I wud go for 505 or velodynes
    Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07
    , logitech 880
    Def Tech Mythos ST :D Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
    2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
    Bed Room: Pioneer Elite VSX-52 , Monitor 50
    Storage-RTi8,CSi5,PSW505,Monitor50
