Wakeboard Boat setup
cbondura
cbondura Posts: 3
edited April 2009 in Speakers
I would like to use all Polk equipment in my boat. I currently have 4 Polk DB 6.5's in the boat and need to add 4 Polk MM 6.5's to the wake tower.
I need to choose a amp to drive all eight speakers plus a sub. I also need a wiring diagram that shows how bridge all eight speakers together.
I am considering the Polk PA1100.5 to drive the system, but I am not sure if that is the best route to go. In the past I have used multiple amps for setups with 4 subs, but I would like to use one amp if it makes sense.
Any help would be fantastic. I promise to post some pics when I am done.
Thanks,
Chris
Post edited by cbondura on
  • nadams
    nadams Posts: 5,877
    edited April 2009
    Hi Chris,
    You would probably get some more responses if you posted this in the car audio section. They're more familiar with the components that you're dealing with. The car audio section is waaaaay down at the bottom of the forum. It's a little dark down there some times... we don't really have the budget to keep the basement lights replaced :p
    An easier way to find it would be to click on this handy-dandy link - http://www.polkaudio.com/forums/forumdisplay.php?f=5
    Just don't say I didn't warn you...
    Ludicrous gibs!
