4 Channel amp in bridge mode for Sub and 2 channel for R/L
rkumarblr
rkumarblr Posts: 1
When using a 4 channel amp. What is the best way to wire the Front and Back speakers and a Sub in bridge mode.
Assuming we connect the Sub by bridging two channels. Can we connect the remaining two channels in parallel to say right (front and back) and Left (front and back)
Of is it advisable to wire the Fronts form the Amp and the Backs from the head unit.
What would match better or what is the rigtht wiring strategy to ensure good matching and performance. Assumimg we use a 150 W per channel at 4 ohms to drive the fronts and backs of 60 W at 4 ohms
Post edited by rkumarblr on
  • Mike21
    Mike21 Posts: 252
    edited April 2009
    Hi rkumarbir.
    Welcome to the Forum.
    It would be helpfull if you could supply the Brand and Model # of the 4 channel amp, your speakers and your subwoofer.
    Mike
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
