Monitor 5 Series 2
dsgreens
dsgreens Posts: 5
edited October 2001 in Technical/Setup
Would anyone like to educate me about the following speakers, I've had a pair for years now (a gift) but never knew anything about them. Maybe a suggestion or two on what to add to it for a home system (I already have a cs245i), and specs.
Dave (Toronto)
Post edited by dsgreens on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited October 2001
    Mon 5's eh, not a bad model from the monitor line....
    Right on with the CS245, what is the budget for rears and a sub? Cheap, but quality way out? 2 R10's bringing up the rear, and PSW250 sub....
    Other options, depending on budget....consider moving the Mon 5's to rear duty, and do either a nice RTi tower or bookshelf up front....many choices here brotha...need a budget to point you in the 'subjectively right' direction....
    Cheers,
    Russ
