whats the word on this subwoofer
BIC AMERICA BICV1220 Venturi 12 200-Watt Powered Subwoofer. Is this a good subwoofer. If it is, I can get a splendid price for it.
HOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
Post edited by royalty on
Give it a try:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Grease
Grease?HOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
Infinity 6032CF's all around -
Grease is the word, or so I heard.
I though bbbbbird is the word.
:p everybody's heard about the bird:D The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Yeah, you can get a splendid price on it because a BIC sub is a basically a big pile of ****.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
You may be better off spending your hard-earned money on a ShamWow.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
...or a SlapChop!
I have two Acoustech (bic america) h-100 subs on my h-t set up and they sound great! also sound great for music too, sure not as good as subs costing 1000's of dollars, but they did sound better than the two Klipsch RW-12's I had before them IMO.
BIC subs sound much better for music than they do for movies, what are you using it for? I have never been impressed with the way they sound though. I am personally partial to Velodyne but I have been out of the game for awhile.Receiver: Marantz SR7002
Fronts: Canton Chrono 509 DC
Center: Canton Chrono 505 CM
Surrounds: Canton Chrono 502 SP
Sub: SVS PC12-NSD
TV: 40" 1080i JVC Multisystem LCD(upgrading to 50" Samsung LED)
Blu-Ray: PS3
DVD: Pioneer DV-420V (HDMI)(for PAL DVD's)
Audio/Music: MacBook Pro hooked up thru HDMI
Gaming: PS3 (oifvet0608) XBOX 360 (JAYtheVET)
Cables: Inakoustik Reference -
I think the Acoustech (bic america) h-100 was considered a very good bargain, the V1220 was not considered as good a bargain. But still a pretty cheap sub with performance equal to it's cost. It boils down to what you have to spend or willing to spend. You would probably be better off increasing your sub budget, even if it means waiting and saving, to get a better sub (even used) so you only need to buy a sub once.
What price can you get it for? I guess if it is really a good deal give it a try, only you will be able to tell if it does the trick for you. -
I would primarily be using it for movies...EXPLOSIONS!HOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
I can get it for 170 shippedHOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
Ive got the H-100 and am very pleased with it yes there are more expensive subs out
there but just how much output do you really need? It is hard to get any decent sub
in the $ <300 range. -
This is where I got mine, Fast shipping, easy transaction. I can recoment this one for the price but dont really know about the other one you mentioned but has to be better than a Sony
http://cgi.ebay.com/H100-BIC-Acoustech-H-100-12-500-Watt-Subwoofer-New_W0QQitemZ140311420486QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item140311420486&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A2%7C240%3A1318
You might try this one also for a few more dollars
http://cgi.ebay.com/BIC-Acoustech-H-100-NEW-MODEL-IS-HERE-VK-12-VK12-NEW_W0QQitemZ200327068987QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item200327068987&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A2%7C240%3A1318 -
The H-100 was designed by Dr. Hsu and for a budget sub, it's pretty darned good. The other Bic models should be avoided. Supposedly the PA-120 (Premier Acoustics) is an improved H-100 or a clone for about the same $$$. Still, after going through a couple of years of sub upgrades a few years ago, budget subs don't cut it for very long. Save some money and get a decent sub...some money = ~ $500.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
2 H-100's sound real good for HT and music. Paid less than 500 for both, now they dont sound as good as the Sunfire I used to have but that was over $1000.
for under 400 delivered I have heard good things about these sub kits from Dayton and the higher end ones as well
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-770
