First post - Crossover settings for RM8, DSWPro600 and Onkyo 806
odub303
Hello all. After having my living room home theater done using a Panasonic 50pz800u, 3 x tc265i, 2 x tc65i (surround back) and 2 x rc65i (side surrounds in ceiling), a PSW505 (I think) and a Denon 3808ci, I quickly became a big fan of polk audio speakers. I just had my basement finished and have installed another home theater area, this time with a Pioneer Kuro Elite Pro 111fd, 6x RM8 front, side and rear surrounds, 1 x RM8 center, a DSW Pro 600 and an Onkyo 806. I am wondering what the optimal crossover frequency settings are for the RM8's when paired with the DSW Pro 600 and an Onkyo 806. As an FYI, I have the Onkyo's subwoofer output sent to the line in on the DSW Pro 600, so I am not running the LFE connection. Anyone have any suggestions? I am currently messing around with 100hz for the fronts, 120hz for the center, and 120 for the sides and rear surrounds. I'm almost positive this is not optimal. Does the low pass filter knob on the DSW Pro even come into play in this setup or does the receiver solely determine the distribution of the audio signal? Lastly, when I ran the Audyssey auto setup, I think it listed the speaker impedance at 6 ohms, but the speaker documentation indicates that they are 8 ohms. Should I override the Onkyo's settings and change the speaker impedance setting to 8 ohms?
Thanks!
Ryan
Thanks!
Ryan
Post edited by odub303 on
Hi Ryan.
Your post:
"I have the Onkyo's subwoofer output sent to the line in on the DSW Pro 600, so I am not running the LFE connection."
I think you are.
The Onk 806 has two ohm settings: below 6 and 6 to 8. So, I think the Audydessy set it correctly.
I rely on the Audessesy for crossover points in my 805 system.
Mike____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
Hi Ryan
Your post:
I think you are.
Mike
Hi Mike. Thanks for the reply. Much appreciated. Is there anyone who manually sets their crossovers for a similar configuration?
Ryan
